Old 09-05-2004, 01:58 PM
RackAtak RackAtak is offline
Boat: FLOATER
HELP Trailer Buddy's Throwing Grease
My automatic wheel bearing greasers are throwing grease all over my wheels. How do I prevent this? How do I remove the "Trailer Buddies" and replace them? Are "Bearing Buddies" a better product?
Old 09-05-2004, 02:32 PM
tph's Avatar
tph tph is offline
I think this is common. I found two things that help
1) Wipe all excess grease from the inner collar of the bearing buddy
2) Purchase and install the bearing buddy bra.
Old 09-05-2004, 02:53 PM
lakes Rick's Avatar
lakes Rick lakes Rick is offline
Boat: MC Maristar 225 VRS 1994 350TBI
I might add:
I had one wheel doing this and couldn't get it to stop.. Turned out the seal was leaking water and the bearing was going bad... Might want to take them out and check them......
Old 09-06-2004, 01:54 AM
DanC's Avatar
DanC DanC is offline
If you do what Terry says and it is still throwing grease, then it is what Rick said. But it is not the bearing, it is the bearing seal. There is an outer seal and an inner seal. Pretty common to blow the seals by over pumping with grease (my dad always believed if a little is good, more is better ) or overheating (common occurance on long down grades)
Old 09-06-2004, 03:46 AM
tph's Avatar
tph tph is offline
I assume that since you said the bearing buddy was throwing grease that you were having problems with the outside of the wheels. If you are getting grease thrown on the inside of your wheels (towards the center of the trailer) you may have a faulty seal. "Lakes Rick" makes a good point. You could be seeing an unusual amount of grease because the grease is combined with water leaking into the hub. In this case, a bra could be hiding a problem. The bearing buddy is pressed into the outer hub of the wheel. I've been able to remove them by tapping around their outer edge with a hammer.
