Old 06-29-2013, 03:19 PM
deminimis's Avatar
Boat: 2004 X-Star
WS 420SQ Power Hook Up Question
Hello Folks,
Is there any reason I shouldn't hook my 420SQ power feed (+/-) to the power feed (+/-) at my Syn6 amp? I've already got the primary wires running over to the amp area, so not issue with that. Also, I have enough primary to run directly off the batts. However, I understand I might get some fuzz if I ground the 420SQ to a ground that is different than the amp ground. Since I've already got nice big fat primary cables feeding the amps, I would think it would be okay to grab power at the amp. Make sense? Yay or nay? Also, why are you reading this and not playing on the river? Thanks!
Never Mind The Bollocks, Here's The X-Star
Old 06-29-2013, 05:00 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
You should grab power at the same place your amps are powered to eliminate any noise
Old 06-29-2013, 05:06 PM
deminimis's Avatar
Boat: 2004 X-Star
Gotcha, but any reason I can't grab it where it feeds into the amp? I can't imagine why not, but perhaps it will cause some oscillating muffler bearing failure or something else I haven't thought of. Thanks.
Old 06-29-2013, 05:09 PM
JRW160's Avatar
Boat: 2003 X2
Should be fine where it feeds into the amp. It's all the same node
Old 06-29-2013, 05:11 PM
deminimis's Avatar
Boat: 2004 X-Star
Outstanding. Thank you.
