Old 05-15-2014, 06:01 AM
weist1013's Avatar
weist1013 weist1013 is offline
Boat: 2001 230
Send a message via Skype™ to weist1013
230vs ballast/ fatsacs?
Hey guys Im wanting to eventually install ballast system but for now I'm just wanting to get some bags that I can fill for now then convert the bags to ballast when I get time.I'm wanting enough weight to surf. What bags can I manually fill now and if I want I can convert the same bags to ballast? I have 2001 230vs.
Old 05-15-2014, 06:41 AM
CantRepeat's Avatar
Boat: No Boat
wakemakers.com can help with bag size.
↓↓↓↓↓ indeed!
Tim
Old 05-15-2014, 08:22 AM
pmikler's Avatar
pmikler pmikler is offline
Boat: 2006 x30
^^^^ whoops wakemakers.com
Old 05-15-2014, 09:19 AM
jafo9's Avatar
jafo9 jafo9 is offline
Boat: 2002 X30 LTR
you can fit off the shelf 1100's in the rear lockers and a 750 off the shelf fits OK in the bow walkway. the surfing pic is with the 1100 in the port corner and the stock KGB ~350# full but no external sacs. in an ideal world, i'd have the 1100's in the corners, a custom wake makers bag in the ski locker and a bow filler sac plumbed in as well. fwiw, our hulls are identical.
Old 05-15-2014, 09:51 AM
CantRepeat's Avatar
Boat: No Boat
That's one of the best waves I've seen for that year hull. Nice job!
Tim
Old 05-15-2014, 09:55 AM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
I have 750s in the rear (950 lbs "fully expanded") and a 650 U shaped sac under the front seats that are fully automated (i.e. flip a switch to fill/drain). I also have a 280 lbs sac that I just fill at the beginning of the season in the front of the ski locker and leave full. I had another 280 filled/drained via a portable pump that I'd put in the walkway sometimes if we wanted a lot of weight for wakeboarding or I'd put it on the surf side towards the rear for surfing.
https://plus.google.com/photos/11416...ISU_smm9bKfpwE
It took some dialing in but for the last couple of seasons it just works and I don't really have to think about it. If you're all about the surfing then I'd get the 1100s for the rear. They'll fit but you won't get them fully "plumped" like you can with the 750s. You might get close to the 1,100 lb nominal weight but you certainly won't get more than that (i.e. you will only fit maybe 150 more lbs in an "1100 lb sac" vs. the expanded "750 lb sac") due to the size of the locker.
Here's the wakeboard wake:
I don't have any pictures of the surf wave. I really just set it up for surfing on a "best effort" basis since I don't particularly care for it. It does work fine though.
Old 05-15-2014, 10:07 AM
Boat: 2000 230 VRS
Also, I don't typically fill the rear completely for wakeboarding. I'll get them close to "full" but certainly not "expanded" (The term FlyHigh/FatSac uses) so they're probably around 700 lbs each for wakeboarding. For surfing I fill the bag to the full 950 lb expanded weight, put the 280 on the floor on the surf side rear corner and partially fill the bow sac sometimes.
Old 05-15-2014, 01:12 PM
weist1013's Avatar
Boat: 2001 230
1100 sacks 80% filled on each side in the rear compartments correct?
i guess will need to relocate the dual batteries.. where should i put the 2 batteries?
Old 05-15-2014, 01:20 PM
Boat: 2000 230 VRS
I only have one battery in the factory location below the port, rear corner seat. If I was going to add a second battery I'd just do dual group 27s which should fit in there. If you have group 29 or 31s then you won't fit two under that seat. You could get smaller batteries or ditch the cooler and put one in the starboard rear corner seat.
Also, do you have the motorized actuator for the rear hatch? If so that will interfere with the port side sac. You'll either need to build something around it to allow it to move while the sac is filled or just get rid of it and do this:
http://www.mastercraft.com/teamtalk/...t=38546&page=3
Old 05-15-2014, 01:26 PM
Bohmer410 Bohmer410 is offline
Boat: 2002 X30 3,000 Ballast
I have two batteries, 24 size, under the rear seat on the port side. They are just before where the floor rasies up under the seat. They fit fine with 1,100 in the lockers.
