Old 06-28-2013, 01:00 PM
x2lakewylie x2lakewylie is offline
Boat: Mastercraft X2 209 RTP
Transmission fluid change?
Anyone change their transmission fluid themselves. My 2009 x2 has 300 hours so i think it is about due. I was thinking or using my oil change pump to change it myself. Anyone had any experience or luck with this?
Old 06-28-2013, 01:15 PM
300 hours? no change? I change mine every season regardless... I use my oil extractor measure what I take out and replace with the same amount...
Old 06-28-2013, 01:19 PM
deminimis's Avatar
Boat: 2004 X-Star
You should suck it out and replace every season if for no other reason than to remove moisture. Shame, shame on you ;-) But, yes, extractor and fill as recommended.
Never Mind The Bollocks, Here's The X-Star
Old 06-28-2013, 01:47 PM
Boat: 1998 Maristar 200VRS
Replacing trans fluid every year is as MCOCD as changing spark plugs every year - yeah, it's cheap, yeah it might prevent a rare problem, but yeah it's unnecessary in most situations. 300 hours? Probably time to change though.
Old 06-28-2013, 01:49 PM
Well said..............still 300 hours
Old 06-28-2013, 02:02 PM
Hogwild's Avatar
Hogwild Hogwild is offline
Boat: n/a
What's the best extractor you guys use to do this? My pump is terrible and takes forever to extract.
Old 06-28-2013, 02:05 PM
deminimis's Avatar
Boat: 2004 X-Star
OCD? Maybe, but me thinks not. You get moisture in there, be it from condensation or from taking it in through the vent (for those that have submarined their boats). Best to just get it out of there and start anew. That being said, we had a drier year this year, my oil looked good this Spring and, admittedly, I didn't suck it out. Last year, I took some in from the vent hose and it took four cycles of sucking and refilling before I finally got all the moisture out of there so maybe I banked an oil change or two (at least that's what I'm telling my guilty self).
Old 06-28-2013, 02:08 PM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
I used the $5.99 hand pump from Harbor Freight, and it worked fine.
deminimis's Avatar
Boat: 2004 X-Star
I used a cheap Plews sucker dealio. It kinda sucks, not in a good way, but it works and it's cheap.
Old 06-28-2013, 02:24 PM
bturner2's Avatar
bturner2 bturner2 is offline
Exactly what I do every year. Cheap, easy and doesn't take long. Once the boat is in the water I check it again and then we're done with it for the season.
I have an electric extractor for changing oil that I use but I'm sure just about anything would work that's similar.
