Old 07-15-2013, 09:22 PM
MI_Corey's Avatar
MI_Corey MI_Corey is offline
Boat: 2008 X1
New floor screws and repairing stripped holes
Is there somewhere online that I can get the stainless "wood screws" that hold the floor panels in place? When taking my floor and a few other things apart there seems to be a short and long size on these. It also seems that pretty much every other one is stripped out. Is there a good way of fixing that? I was thinking maybe fill the hole with a two part epoxy and when it dries use a small drill for a pilot hole and then screwing the new screw in? Anyone with experience fixing and replacing these? I know they really aren't a big deal and everything pretty much stays in place without them but it bugs me.
Old 07-15-2013, 09:28 PM
That is how I fixed mine.. I did not want to put new holes in my stringers or floor... as for stanless steel screws I got mine at ACE Hardware.
Old 07-15-2013, 10:11 PM
88 PS190 88 PS190 is offline
IMO - if you have a stripped out hole - you should use epoxy but you should also use something with structure.
My personal favorite is plastic dowel of the appropriate size, scuffed up and crammed into the hole with the epoxy - you then drill/insert your wood screw.
Old 07-15-2013, 10:14 PM
lakeoz tristar's Avatar
I used fiberglass and a golf tee to pack the holes good and tight several times to fill them good but I already had the carpet out and floor scraped clean so not sure this is the best option for you.. I got the screws at Menards and Lowes pretty easy to find at most local hardware stores also got new washers for some of the ones that were warped out of shape.
Old 07-15-2013, 11:19 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
I've been known to epoxy toothpicks is holes...
/spôrk/
Old 07-15-2013, 11:27 PM
Skipper
Posts: n/a
If you first mix up a batch of epoxy resin 50/50 with mineral spirits you create a product similar to Rot Doctor. Use a dropper or similar device to force that into the holes. The thinned epoxy will be pulled into every crack and crevice to form a solid bond. Once that cures then come back with epoxy mixed with either West Marine 403 or 404 fibers (or similar products) to produce a paste. That keeps a 50/50 mix of resin and material. Pack that into the holes and allow it to cure. You will have a totally sealed repair. You can re-drill and install new screws.
I have found stainless steel screws at Lowes, Home Depot, and True Value.
Old 07-23-2013, 08:20 AM
Boat: No Boat
I use resins and mix it thick with this filler.
http://www.fibreglast.com/product/11...ers_29/Fillers
http://www.fibreglast.com/product/14...ers_30/Fillers
