Old 06-26-2013, 12:23 PM
colin382 colin382 is offline
Boat: Mastercraft 205 Formula 382
boat died while running
my 2000 205 prostar was running great and just stopped while running down the river nothing when I turn key nothing, no gauge movement no alarm whole dash is dead could that be my MDC box if it was my kill switch it would still crank correct? battery is fine my radio is direct wired to it and works
Old 06-26-2013, 12:25 PM
Yes kill switch would allow engine to turn.
check connections... could be corrosion. Is there power to the dash?
Old 06-26-2013, 12:31 PM
Ground wire at the block is a likely culprit.
Old 06-26-2013, 01:00 PM
no dash is dead gauges stuck in position they were in when boat died
Old 06-26-2013, 01:15 PM
sorry what I mean is there voltage at the connection to the dash or the MDC unit.
Old 06-26-2013, 01:50 PM
don't kno will find out that would make a lot of sense thanks
Old 07-07-2013, 01:43 PM
Mookster Mookster is offline
Boat: 2001 Prostar 205V
I have the same symptoms as Colin382, with a 2001 Prostar 205V. Middle of mild acceleration on the lake, boat went dead, gauges frozen in place, can crank the starter, but no spark. Boat was running great for the last 3 days, and had been running for about 35 mins before the incident.
Have checked and jumped the kill switch, and found that the "accsy 2" breaker is popping when kill switch is bypassed. Bypassed the accsy 2 breaker with a 25a fuse, and that blew the same way, soon as key is turned "on"
Would LOVE to hear if anyone has any ideas or similar issues they worked through. Has me stumped (as well as my car-guy brother in law..)
Old 07-07-2013, 01:46 PM
Oh, and I do have 12v to the dash rocker switches and my depth guage turns on with key, but not sure if I have power to the MDC, will check that shortly.
Old 07-07-2013, 01:57 PM
Check the breaker on the engine.
Old 07-07-2013, 02:20 PM
Thanks for the quick reply! Breaker at engine was checked (double checked), that was my first idea after checking the kill switch.
After further troubleshooting, we have found that we don't have power to the Coil, no 12v showing up on the 4 wires coming into the coil. With key in RUN position, or when cranking the starter.
Checking to make sure there is power at MDC now.
