Old 10-07-2005, 12:14 PM
jmo_54729 jmo_54729 is offline
Boat: 2000 MC ProStar 190
Exclamation Battery Maintainer
Has anyone ever attempted to connect a battery maintainer to more than 1 battery. In other words,
I'd like to take 3 12-volt batteries, (all charged) and
connect them in parallel, then connect the battery maintainer to all three, so that I don't have to keep rotating through the batteries all winter, or buy 3 battery maintainers. Battery maintainers are the little "wall wort" power supplies that keep batteries charged up when you're not using them.
Anyone see a problem with doing this?
Jim
Red/White 2000 MC ProStar 190
Predator 310 HP Four blade prop
Old 10-07-2005, 12:29 PM
lakes Rick's Avatar
lakes Rick lakes Rick is offline
Boat: MC Maristar 225 VRS 1994 350TBI
I "think" I have seen maintainers designed to charge more than one battery at a time.......
Old 10-07-2005, 08:19 PM
Psheehy Psheehy is offline
Boat: 2002 X-7
You can hook them up in parallel to see. Nothing to loose. Measure the voltage across the battery terminals. Each battery should read close to 14 volts if it is indeed charging. The amps (rate of charge does not matter to you). The unit might get overloaded though carrying the load of 3 batteries & quit if the state of charge on any of the batteries requires the charger to work too hard. Paul Sheehy Douglas Battery Winston-Salem, NC
Old 10-07-2005, 08:27 PM
PointTaken's Avatar
PointTaken PointTaken is offline
Boat: 1991 prostar 190
Jim
3 batteries? What kind of system do you have in that boat? Feel free not to answer, as I may feel obligated to upgrade mine if it sounds good
Old 10-14-2005, 09:22 AM
gregg gregg is offline
Boat: 2002 Maristar 210 W/Zeroflex Tower
Jim
I have 2 batteries in parallel and have had no problems at all. I installed and hard wired a Guest 5x2 bank marine charger in my 2002 Maristar 210. 5x2 simply means it charges at 5 amps per bank(battery). A battery's biggest enemy is setting in a state of partial or complete discharge. After a day of running the stereo hard, when I get back to the shop I just pull the cord out and plug the charger in. Next morning both batteries are fully charged and ready to go. Also setting idle during the winter months, I plug it in every couple of weeks to keep the batteries fully charged, or you can leave it plugged in all the time. If you look in Bass Pro's Marine catalog they also have 3 bank chargers for your application. If you are using Marine batteries, make sure you get a marine charger, they are different that a normal starting battery charger.
Old 10-14-2005, 09:32 AM
Leroy
If the same type you will probably not have any problems however if different types or sizes you could. Technically you should have some isolation for each battery. Depends if there is a different "holding voltage" in each battery.
You could do that by putting a 30-100 ohms several watt resistor from Radio SHack in line with positive lead to each battery.
Old 02-06-2009, 02:44 PM
hillbw
Wink 3 bank hookup
Minn Kota makes a MK-35 3 bank battery maintainer. Mfr. # 1820350, Model # 2259909. Sells for around $100.00. This will maintain three batteries at the same time. You just have one unit that has connections to all three batteries. This is a lot better than having one unit for each battery. This unit comes in 6 or 12 volt.
Old 02-06-2009, 02:50 PM
brucemac's Avatar
brucemac brucemac is offline
like leroy said not recommended, especially if they are different.
why don't you just pick up a second 2-bank battery tender? they're like $60 or so I think on amazon.
¡Viva 205v!
2003 X-2 MCX
Old 02-06-2009, 03:46 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Cool deal! Anything for a 2-bank?
Old 02-06-2009, 03:47 PM
Sodar's Avatar
Naw, it would be better to have one unit that you could mount that was connected to all the batts. Just pull in the garage and plug an extension cord in... next time you took off, the batts would be ready for action!
