Old 06-25-2013, 06:08 PM
andersonmc andersonmc is offline
Boat: 2001 X star
Info on 310 vs 330 motor
Looking at a 01 with the 5.7L 310 motor. Is that still a strong motor or is the 330 a lot better?
Old 06-25-2013, 06:16 PM
corey's Avatar
corey corey is offline
Boat: X10
The standard TBI engine is perfect in an 01' X-Star, the upgraded motor was called the LTR, my understanding is it is the same block, cam and heads with a different intake and ignition system.
Old 06-25-2013, 06:17 PM
nickespi's Avatar
nickespi nickespi is online now
Boat: 2002 MasterCraft X-30
I have the 310 in my 30. It ran decent before with boarding and surfing. I changed out the prop and it runs much better now. I don't feel I'm lacking power, but I've only known the 310.
Old 06-25-2013, 08:46 PM
46Chief 46Chief is offline
There's a true hp thread somewhere in here. the 310 is supposed to have a better torque curve. I replaced my 330ltr with a 310 predator because I couldn't find an intake manifold to overhaul the motor that came with my block. Can't go wrong either way I think.
Old 06-25-2013, 09:36 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
The 310 is plenty. With a 14.25x14.5 prop, mine gets out of the hole no problem with 3000lbs of ballast plus 6 people.
Old 06-25-2013, 10:22 PM
Boat: 2001 X star
You think that is the best prop set up for running a lot of ballast?
Old 06-25-2013, 10:52 PM
88 PS190 88 PS190 is offline
Always contact the mfg for recommendations on props, OJ or ACME both make a hell of a product. How much % of the time do you plan on having the ballast full? I think some folks either overestimate how much boarding they do vs. cruising, or otherwise don't empty their ballast very often.
Old 06-26-2013, 03:09 PM
JRW160's Avatar
Boat: 2003 X2
Mine is the stock prop I got off a buddy's 07 x2. I have no complaints with it. As stated above, getting in touch with the prop manufacturers is the best idea. They will often send you a couple to try out. This thread provides a pretty good overview of some of the options.
http://www.mastercraft.com/teamtalk/...ad.php?t=50200
