You are missing my objective. On a boat this size you are arguing what is on 40'+ boats and comparing it to this. The correct term if you want to get all vocab nazi on me is "all around stern" light. It doubles as both lights on boats under 24'
I'm not saying you are wrong, so stop arguing. Just stop making it confusing on what the lights purpose is and how it connects to that particular switch the OP was asking about. nuph sed. http://www.premiumpowersports.com/Pe...ght-p-406.html That is a Perko "all around/stern" light. It doubles as both on our boats hense why the switch will only illuminate the one for anchor and both nav and stern/all around on nav. It is dual purpose on this size boat and you are getting way to technical. Like I said. You are not wrong. I never said you were. You were just a bit confusing with your 100% proper explanation so I clarified it in simpler terms. Thats all. Hope you have a good day.
1 Corinthians Chapter 13 - 11 |
#12
Sorry, didn't realize I was confusing.
2006 X-9 MCX |
#13
Wow.. and I just wanted to know which switch. But got so much more info for knowledge
#14
360 Light Flickers
So I was in the same situation, not getting my light to stay on. I was thinking that maybe the boat needs to be running, but that seems odd with such a low draw on the battery. When I switch the nav lights on and off the tower 360 light turns on quickly then off even though the port and sb nav lights are on. I am thinking the wiring may be loose; any experience with this or suggestions?
#15
Check the bulb, in my case it was the Bulb. You may just need to clean the contact points inside too.
Thread Tools | |
Display Modes | |
