Old 06-25-2013, 01:48 PM
memphis23's Avatar
memphis23 memphis23 is offline
Boat: 1988 190 prostar
Anybody used one of these before?
http://www.insanitypylons.com/insani...roducts00.html
thoughts?
Old 06-25-2013, 01:50 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
A friend bought one for his monterey I/O right as we were getting into wakeboarding.
It worked OK on that I/O. Problem was the wake sucked.
I don't know why you would ever consider one for an inboard, I'd stick with the regular extended pylon.
Bailey
'02 X-9
Lake Blue Ridge
Old 06-25-2013, 01:55 PM
memphis23's Avatar
Not putting it on my boat my brother in law has a I/O he was considering putting it on. It sure doesn't look like it would be secure enough for me?
Old 06-25-2013, 01:56 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
It did work OK.
Broke a strap once pulling a tube- probably wasn't a good idea.
Worst thing about it was we were then trying to wakeboard on an I/O- losing proposition.
Bailey
'02 X-9
Lake Blue Ridge
Old 06-25-2013, 02:12 PM
memphis23's Avatar
thanks for the reply he was looking at this one and the ones you drill a hole in the floor. I would think that would be more secure but also a permanent screw up if he did not like the outcome with a hole in his floor.
Old 06-25-2013, 02:24 PM
madcityskier's Avatar
The holes would likely be lost in the carpet if you change your mind and want to remove, see what size screws. I/O will generally require ballast in the middle of the boat. We had a sac between the windshield halves above the ski locker. It helped, but not as much as going to an inboard, which is not nearly as good as the neighbor's v-drive. Though I've never had 2000lbs ballast in my 85.
