Old 06-21-2013, 01:41 AM
svxwilson svxwilson is offline
Boat: Ski Brendella, Super Comp, 1991, 351 Windsor
New engine, new prop?
I just got my new engine installed and used it for the first time today. I went from a stock 351w with 210-240hp to a 300hp 351. The engine builders said do not take it above 4600rpm and should cruise under 4200rpm. At 4000rpm I am just barely getting to 30 mph. The old engine had similar results. It gets there in one hell of a rush. I have a acme 543 on it now. I have way more than enough bottom end so I can sacrifice in that area to get faster top ends. It has a 25/1 PCM gearbox.
Old 06-21-2013, 07:11 AM
ProStar Slalom's Avatar
ProStar Slalom ProStar Slalom is offline
Boat: 1984 S&S, 2001 19 Skier
Something isn't right...either tach, speedo, or prop. No reason to be turning 4000 at 30mph, should be around 3000-3100.
Old 06-21-2013, 08:49 AM
jk13 jk13 is offline
Boat: Not a Mastercraft
You mean 1.25:1? That's a powerslot transmission and you have a prop for a 1:1 on there--and a low pitch one at that. My brother also has a modded 351 but he has a 1:1 transmission and runs the 541 (one pitch higher) with no problems at all regarding holeshot and top end. You are geared lower and pitched lower than he is.
Call Acme and they will get you set up with what you need.
Old 06-21-2013, 08:53 AM
Table Rocker's Avatar
I am confused by the setup. Your engine is reverse rotation, but your prop is LH? Adding to the confusion, I found this on ski-dim:
3BLD LH PROPELLER 1" BORE
14 X 16 LH, SKI BRENDELLA WITH RH ENGINE RUNNING PCM 1.23:1 TRANSMISSION. THIS ONE'S FOR YOU!!!
I think I can safely say you need a steeper prop.
Okay, further reading shows that the PCM Model 40A transmission reverses rotation. I would guess you need that prop listed above. Most gear reduction props are going to have something other than a 1" shaft.
'96 ProStar 205 SD LT-1
Old 06-21-2013, 09:09 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
You are going to get better advice if you post somewhere where people are familiar with PCM powertrains. Try correctcraftfan.com.
Old 06-21-2013, 10:53 AM
I was running from memory and that was a bad idea. It is a 1.23/1 ratio. I just got off the phone with acme he recommended a 1793 which is a 13.5 /14.25 4 blade .105 cup. I think I am going to roll with that. The acme guy said if it doesn't work well he will let me return it for a full refund on exchange for another different prop.
Old 06-21-2013, 10:59 AM
It is looking like I will have a like new acme 543 for sale. I think I am going to pull the trigger on the new prop that is actually for my boats set up. The acme guy wasn't sure why they sold the previous owner the 543 as it wouldn't work that well even on my factory set up. My only thought was the old engine was so tired and wore out it needed that 543 to pull people up.
Old 06-21-2013, 04:31 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Plenty of PCM's in Mastercraft's
Sure looks like a LH to me and not RH
His LH Prop
My LH Prop
/spôrk/
Old 06-21-2013, 04:58 PM
It's his PCM transmission that is odd. Right hand rotation engine reversed to a LH prop.
Old 06-21-2013, 06:42 PM
His LH Prop
Attachment 97260
My LH Prop
Attachment 97259
The correctcraft forum doesn't have nearly the amount of helpful people either. I have tried both.
