Old 06-21-2013, 07:13 AM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Originally Posted by uplander View Post
stupid question but did you check the oil was it milky looking, had a friend with bad gaskets and the water got in the oil.
Yes checked oil. Was not milky in any way. Or low or dirty. Beautiful in fact.
I guess it's more of a pop than knock.
We did locate the noise to be an exhaust leak. My mechanic and I spent about 25 minutes running up and down the river. At all different rpms. I never noticed a loss in power.
1 Corinthians Chapter 13 - 11
Old 06-21-2013, 03:04 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
I don't "think" an exhaust leak would cause a big enough harmonic noise in the block to trip the knock sensor. 95 EFI does have a knock sensor in one of the block drain plugs.
If you ran it again with the exh leak and not running rough it may have just been an anomoly that it ran rough the first time.
You dont say which gasket. Manifold to head or manifold to riser?
Mike is correct on the riser gasket could potentially be blown out on the inside surface as well and allow water into the dry side of the exhaust.
If it's the gasket on the head then run it as long as it's not a big exhaust leak, maybe leave the blower on, think CO2 in the engine box.
Either way it's theoratically a simple fix save for every exhaust seems to have stubborn rusty bolts that wont come out or break.
I'd park it and start hitting the bolts with penetrating oil. Trick to getting out rusty exhaust bolts. If you can heat up the portion that the boltis threaded into head or manifold and not the bolt per se, with a cutting torch (even Mapp gas will work but will take alot longer) you can usually remove the bolt easily because the piece the bolt is threaded into expands slightly braking the rust bond in the threads.
'06 X2 MCX
Old 06-21-2013, 03:36 PM
Rockman's Avatar
Rockman Rockman is offline
If you run it, then you will definitely find out what the problem is then!
How old is the knock sensor?
Put it this way though, motor cannot get any BETTER by running it at this point. Can he hook it up to the computer and see if any codes are coming thru?
I have an extra knock sensor if you want to test it with...
Old 06-21-2013, 04:05 PM
Traxx822's Avatar
It is the gasket on the head. My manifold to riser gaskets are seeping but not leaking like crazy or anything.
Maybe the sound with the cover down tripped the knock sensor. The problem is on the port side.
My knock sensor is original. So Rockman I might take you up on that
We did hook it up to see if any codes were thrown and nothing at all came up.
Old 06-21-2013, 04:27 PM
cal69 cal69 is offline
Boat: 1992 PS 205, 351 HO 1:1
Did you pull all plugs to make sure water is not getting into the cylinder from a leaking riser gasket? I think you really want to rule that out. Hydro lock is a bad thing. Just went through this on a buddies Malibu. He got lucky and only blew the head gasket. It was a knocking noise like you describe and still ran (though roughly). Just something to consider.
Old 06-21-2013, 04:30 PM
Traxx822's Avatar
I didn't but my mechanic did. And everything is ship shape as of now. The riser gasket is just seeping very minimally and is not my pressing concern
Old 06-21-2013, 04:32 PM
Thumbs up
Ok. Good to hear. Sounds like you have the issue sorted out.
Old 06-21-2013, 05:13 PM
Rockman's Avatar
Ok, let me know. I replaced mine last fall and this was the one that came with the boat when we bought it last fall...it worked fine, no issues, but just wanted to replace it as the outer looks of it was worn.
I am sure it would work if I needed to put it back in ours.
Let me know.
Old 06-21-2013, 10:13 PM
bsloop bsloop is offline
Boat: 91' MC 240sc
Replace the gasket. $25ish for the gasket and bolts plus an hour or two.
As mentioned, you will want to check the mating and wall thickness. When I had my leak, we found how pitted the faces and thin the walls had become. Knocking off some of the rust further up the elbow showed how close they were getting to allowing water into the cylinders.
So, what I am saying is, fix the easy leak but go in knowing there is a decent chance you will be forking out $300 a side for new exhaust and risers.
Old 06-21-2013, 11:09 PM
Traxx822's Avatar
Anyone have a good tip on riser replacements. Maybe in chrome. I could use the excuse
