Old 07-02-2013, 01:46 AM
BoulderX45 BoulderX45 is offline
Boat: MC, X-45, 2006, LQ9
Ballast Pump Replacement
I just had a ballast pump fail in my 06 x-45. Do I replace it with the Jabsco (current pump) or Johnson? Does the Johnson have the same hole pattern? Same power plug? Does it pump more then the Jabsco as stated?
Thanks,
Boulderx45
Old 07-02-2013, 08:15 AM
Boat: No Boat
You could use either one. Everything I've read says there really is no noticeable difference in the pump rates.
Old 07-02-2013, 08:49 AM
bturner2 bturner2 is offline
Wakemakers told me to replace with the same as what was installed when I looked into going to the Johnsons. You'll need to cut and solder the connector onto the new pump unless you buy the pump directly from MC).
Old 07-02-2013, 09:33 AM
Boat: No Boat
Or you can get a set of pins and then just repin the old connector.
http://www.deutschconnector.com/prod...es_connectors/
Old 07-02-2013, 09:42 AM
ZachDaddy's Avatar
My buddy's pump failed and he had his rebuilt for $75 dollars at a local alternator shop. I've helped a number of others on this forum with the same problem.
Old 07-02-2013, 10:00 AM
BrooksfamX2's Avatar
Boat: 2007 X2
Had my port side pump failed last week. Bound up like the bearings are shot. Replaced with a Jabsco from Wake Makers last night. They shipped it overnight for free!!!
Will autopsy the old one to see what's going on. Will refurb and keep as a spare.
Need to turn them over so they don't leak into the motor...........
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
