Old 06-19-2013, 01:33 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Acme 1285 vs 1479 -- any experience?
I'm currently running an Acme 1285 on my 05 X2. (Was installed by the PO.) We board and surf but also slalom. I contacted Acme for suggestions on a prop that might lower my RPM's when skiing but still provide low end grunt. They suggested that the 1479 would lower my RPM by a couple hundred. Same diameter and pitch as the 1285 but .150 vs .105 cup. Anyone have experience with the 1479 prop? I'm not sure if it's worth the $$ just for a small change. I do know I could sell my 1285 in a heartbeat.
Old 06-19-2013, 12:00 PM
EJ OJPROP's Avatar
EJ OJPROP EJ OJPROP is offline
What engine is in the boat? EDIT - Just saw the MCX engine. How much ballast do you typically run?
Eric Johnson
Johnson Propeller Co., Inc
ojprops.com
800-359-9730
Old 06-19-2013, 01:18 PM
wheelerd's Avatar
Boat: 2005 X2
For surfing we run about 1500lbs.
Old 06-19-2013, 02:32 PM
EJ OJPROP's Avatar
To drop the RPM for skiing and still have decent low end while loaded I would suggest our 14.75 X 15.5 LC Splined XMP EDGE 4-blade.
Eric Johnson
ojprops.com
800-359-9730
Old 06-19-2013, 05:55 PM
thamax thamax is offline
Boat: None
I ran the 1479 for awhile. I have both a 1285 and 1479. Both worked good for surfing 3200-3300 Rpm with alot of ballast. At 12 mph wakeboarding not much difference between them. 1285 had a higher top speed by 3 mph with no weight in the boat. I am running the OJ TZ X-5 right now and I feel it's a better all around prop running Serious weight while surfing and wakeboarding. Fuel economy is up for sure
Last edited by thamax; 06-21-2013 at 03:09 PM. Reason: willyt doesn't like my sentence
Old 06-20-2013, 02:36 AM
wheelerd's Avatar
Boat: 2005 X2
Originally Posted by thamax View Post
I ran the 1479 for awhile I have both a 1285 and 1479 worked good for surfing 3200-3300 Rpm with alot of ballast at 12 mph wakeboarding not much difference the 1285 had a higher top speed by 3 mph with no weight in the boat I am running the OJ TZ X-5 right nowand I feel it's a better prop all around with serious weight and surfing and wakeboarding I know my fuel economy is up for sure
Your 1285 had a slightly higher top speed than the 1479? That seems to be at odds with what Acme indicated would happen for my boat.
Old 06-20-2013, 08:05 PM
Boat: None
Not much I think 43 mph and 40 was spread on them but I need to retest this year when I get a chance I am in a 4300 lb x-star mcx with a hotter cam so like 10-15 hp above stock
Old 06-20-2013, 08:06 PM
Boat: None
At 4000-5000ft elevation
Old 06-21-2013, 10:05 AM
wheelerd's Avatar
Boat: 2005 X2
Thanks Eric. Any idea what the approx. RPM gain would be at 34 mph running unweighted?
Old 06-21-2013, 10:09 AM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
That... Was the longest sentence I have ever read
