Old 06-17-2013, 11:56 PM
bret's Avatar
bret bret is offline
Perfect Pass, 94 TBI
http://www.ebay.com/itm/MASTERCRAFT-...f9b216&vxp=mtr
Listed as 99-01 but should work on 94? TIA
Old 06-18-2013, 05:30 AM
Boat: No Boat
You could give Perfect Pass a call with the part number and I'm sure they would help out.
Tim
Old 06-18-2013, 08:56 AM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
It will work fine. May require a different length throttle cable but might not. Everything else is the same. New throttle cables are cheap if indeed you need a different length.
Old 06-18-2013, 09:01 AM
Ski-me's Avatar
Ski-me Ski-me is offline
It looks to be the single line display instead of the 3 line display and it looks to be the older 6.4 software.
When I installed, I went with the 3 line and version 6.5ng. With the 3 line display, you have the ability to upgrade to the Stargazer without replacing the gauge. Although I've never used or seen the single line, I would suspect it's not as easy to scroll through the menus, settings, etc.....but guessing there.
Anyways, just an fyi. Definitely worth adding Perfect Pass to your wish list though. GREAT addition!
I found a used module and then bought everything else new from PP (display, servo, servo cable and electrical cables). I paid about $100 for module and around $500 or $600 for the new parts. I am in RPM mode only so no paddle wheel, timer, magnet pickups, etc. The package at Skippers appear to have all that included.
- Jeff
1994 205, LT1
Old 06-18-2013, 10:29 AM
VTJC VTJC is offline
Boat: None
I began using PerfectPass with the small display and find I prefer it to the multi display. While the multi display now has advantages with Stargazer and Z-Box. I found smaller display easier to use, since the larger display used sub menu’s and buttons for multiple purposes that is confusing.
This price seems a bit high for an outdated setup.
Currently Boatless
Previous Boats:
99 MasterCraft SportStar CB
98 Moomba Boomerang 310 HP 350 Carb
88 MC PowerSlot 240 HP 351 Carb Black on White
