Old 08-10-2013, 02:01 AM
PremierPOWER PremierPOWER is offline
Boat: Lots
X Star Starting issue, possibly fuel pump
Well long story short, we ran the boat all week while tuning the speakers and t started and ran fine every time. Towed it 5 hours down to lake Cumberland today and it started for 5-10 sec and now nothing (seems it just burned the fuel in the lines up). We took the valve stem cap off And pushed on the stem to see if fuel was coming out (could hear the fuel pump on ignition, and verified no pump with kill switch pulled). It just cranks and cranks as if the kill switch is pulled but its not. I'm limited on tools and diagnosing equipment down here but I can't imagine what else it would be. Any suggestions as we are trying to make an event tomorrow.
- 1996 Donzi 22 Classic Blackhawk Limited Edition w/ 500hp Mercruiser 502
- 2001 Sea-Ray 240 Sundeck w/ Mercruiser 383
- 2005 Formula 382 FasTECH w/ Twin Mercury Racing HP600SCi
- 2008 Donzi 43 ZR w/ Triple Mercury Racing HP700SCi
- 2009 Meridian 441 Sedan Bridge w/ Twin Mercruiser Cummins 480
- 2014 Regal 27 FasDeck RX w/ Mercruiser 8.2 Mag
- 2016 Nor-Tech 390 CC w/ triple Mercury 350's
Old 08-10-2013, 06:46 AM
André's Avatar
André André is offline
Boat: Prostar 190 1994
So,was there fuel pressure when you pushed on the schraeder valve...
If no fuel,the first suspect ,as usual,is the fuel pump.
Read the -Fuel pump 101- thread.
Good luck!
Keep skiing!!!
Old 08-10-2013, 07:36 AM
Boat: Lots
Whoops forgot to write in that no fuel when I pushed the Schrader valve. I'm trying to find a compatible 60psi fuel pump from napa or auto store since no dealers anywhere close
Old 08-10-2013, 11:24 AM
Boat: 2006 X30
Airtex E2044
Old 08-10-2013, 05:03 PM
oumiller28's Avatar
oumiller28 oumiller28 is offline
Boat: MasterCraft, X-Star, 2007,
I had the same issue with my 07 X-Star with just over 300 hours on it. I have seen people say just to replace the pump. After I pulled everything out I think I should replace the fuel filter too. Any thoughts or suggestions? I see replacement parts for the pump (airtex E2044) but nothing about the fuel filter. I have no clue where to get the replacement filter, other than ordering one from MC.
All help is greatly appreciated!!
Old 08-11-2013, 05:01 PM
Boat: Lots
Got up early yesterday and the guy at auto zone cross referenced the airtex 2044 with the part numbers I found on the 101 thread. Got the pump installed in about 1/2 hr and boat ran great all day! Need to change the filter now but the original pump lasted 575 hrs
Old 08-11-2013, 07:06 PM
awesome!!!! Love reading the the quick reasonable fix!!!!
Old 08-11-2013, 10:28 PM
Jerseydave's Avatar
TT Hero
skidim sells the fuel filter.
Just curious, ever run your tank below 1/4 tank of fuel? If so, don't do that anymore. With little gas around the fuel pump it will run hot and fail early.
I was njskier on here.
