Old 10-10-2015, 01:46 PM
skiboyny skiboyny is offline
Boat: 1996 Prostar 190
Floor panel replacement
I have a 96 prostar and the honeycomb aluminum floor panel that holds the motor box is shot! Been looking around and it seems most people replace it with wood. Although I hate that idea the options seem few. What are you guys doing to seal the wood. Fiberglass resin? Matting? Looking for a decent way to approach this. It is a high traffic, high moisture area.
Old 10-10-2015, 01:48 PM
show a picture - I rebuilt mine.. you can buy finished pieces here.
Honey comb floor panels
http://flatironpanelproducts.com/Fla...s/Welcome.html
http://medallionis.com/ - medallion parts boxes and gauges.
Old 10-10-2015, 03:42 PM
Thanks Mike,
Will check the links. Who did you use?
Old 10-10-2015, 03:51 PM
Originally Posted by skiboyny View Post
Thanks Mike,
I fixed mine... filler with glass strand and then wrapped with 2 layers of glass and resin.
Old 10-10-2015, 03:58 PM
and some more pics
Old 10-10-2015, 04:58 PM
I haven't taken mine out a striped the carpet off yet. I have a feeling it's beyond repair. Been bad for a long time. Did you drill holes in the top sheet and pour resin in? Remove the top sheet somehow?
Old 10-10-2015, 04:59 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
I used 3/4 plywood coated with fiberglass resin, no matting. Worked great.
I used the old one as a template and was able to reuse the carpet.
OH-IO!
Old 10-10-2015, 05:01 PM
all I did was fill in any parts that felt weak.. added a piece of sheet aluminum where the hinges go. flipped the piece around and used the piece that was by the tank to attach motor box hinges.
Old 10-11-2015, 08:01 AM
swilke318 swilke318 is offline
Boat: 1986 MasterCraft ProStar
Do you put any fat sacs or ballast in the back? If so, just buy 3/4" plywood and coat heavy with kilz or similar sealant. When it goes bad pull it out and repeat. Should last 5 years at least. Just go light on the glue if you want to reuse the carpet.
Sent from my SM-N900V using Tapatalk
Old 10-11-2015, 12:47 PM
Shaun R's Avatar
Shaun R Shaun R is online now
Boat: 2011 X25
This is what I did and going strong after a year of heavy use. Had to double up the carpet to make it flush with the rest of the floor. I will have a friend weld up a two piece floor if I decide to keep the boat for another year. Prefer to have a small panel that the motor box is permanently attached to another another that can be pulled up to service the shaft seal and rudder.
