Old 06-16-2013, 10:12 AM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Rear Locker Improvements
This is a picture of where I added a screw so the brackets that hold the plastic boards in place inside the rear locker don't move. When I filled my 1100 lbs sac, the plastic board slipped out of that bracket, result wasn't any damage, but had The motor been running, the plastic board would be in harms way.
I also needed to move one of the brackets holding the permanent plastic pieces.
I secured all 4 like that.
Old 06-16-2013, 08:09 PM
ZachDaddy's Avatar
Good idea!
Old 06-19-2013, 01:14 PM
thamax thamax is offline
Boat: None
I would a vertical piece of angle iron to support the plastic divider as well 1,100 is alot of weight this what i did and it works very well and does not effect access to anything and looks factory
