Old 06-16-2013, 05:36 PM
Bluccous's Avatar
Bluccous Bluccous is offline
Boat: 1985 stars and stripes
Thinking of going back with a blaster 2 or flame thrower coil. I need a 12 volt non resister coil . Does any one know if these coils will work?
Old 06-16-2013, 05:46 PM
Bluccous's Avatar
I think my problem is that my engine is not wired for a stock coil, but it has a stock coil on it. It has been getting to much voltage put on the coil since the resister wasn't being used. I am planning on the flame thrower coil maybe that will fix it. Also did s compression test all cylinders were in the 135 to 120 range except # 2 cylinder it was 115 does this warrant a overhaul or can I run it?
Old 06-16-2013, 05:59 PM
Bluccous's Avatar
On the flame thrower or blaster 2 coil. What should I set the gap on an autolite 24 plug?
Old 06-16-2013, 06:12 PM
Bluccous's Avatar
Doesn't have a wire, or doesn't have a green wire? The color doesn't matter as much as whether it has a wire. If you see a red wire (or orange) AND a purple wire, the purple wire does what the green wire does, except that it goes through the ignition key.
It doesn't have a wire. It appears that they were just using one side of the resistor for a terminal block.
Old 06-16-2013, 11:05 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Spark plug gap .035", the compression is 15%, limit is 10% out not by much I'd run it and recheck later in season. A coil that has a primary resistance of 1.2 ohm or less does not need a ballast resistor. Msd blaster coil 2 is .7 ohm primary resistance, so it should be good to go. That spec was giving to me by msd tech support.
/spôrk/
Old 06-17-2013, 08:54 AM
Bluccous's Avatar
Thanks Mccreight . Awesome info.
Old 06-22-2013, 03:21 PM
Tom190driver Tom190driver is offline
Boat: Mastercraft prostar 190 1990 351w
Good CAN i get some help with hoe to wire a Mallory Breakless ing. in a 351w boat is 1990 PS 190 with a stock coil.Skidim said to the coil or the ballast resister but the ohms on the coil are 1.1 to 1.5 don't want to burn the thing up. Thanks
Old 06-23-2013, 01:48 PM
Bluccous's Avatar
If your coil ohm is below 1.1 u can get away with not running a ballast resistor. My coil is a blaster 2 and I have the factory distributor. It is running great. But my resistor isn't being used. The ballast resistor is mainly for a point style ignition or higher ohms coil.
351 windsor, ballast, resistor coil
