Old 06-15-2013, 09:18 PM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
'89 351 Indmar constantly 140 degrees
My engine in '89 Tristar never gets much past 140 to 145 deg after running constantly at about 2500 rpm's. Does that seem normal for this engine? I thought I should be running closer to 160 constantly? If that seems cold, I'm guessing start by checking gauge, then sensor, then thermostats, right...
Old 06-15-2013, 10:04 PM
slushpup's Avatar
slushpup slushpup is offline
Boat: 89 tristar
Dumb question but, a 351 will run arond 140 with no T-stat,Are you sure it's in there? I Forgot one season To replace mine, Boat ran cool and annoyed me till found it in the glove box.
extreme tube tower
Old 06-16-2013, 09:35 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
That's a true statement an open or missing thermostat will operate a 351w at 140 degrees.
First I would check the thermostat, that's the easiest and cheapest item.
/spôrk/
Old 06-16-2013, 10:22 AM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
The 351 has a 140 thermostat. If you are running at 140-145 you are right where you belong.
Engine Nut
Indmar Marine Engines
Power to the Sport
Old 06-16-2013, 10:25 AM
Dino Don's Avatar
Dino Don Dino Don is offline
Boat: mastercraft 190 1987 351 Indmar
Mine ran that way until I replaced it and now it's at 160. Engines can run too cool as well as too hot.
Old 06-16-2013, 12:46 PM
homer12's Avatar
Well, I've never touched the thermostat so probably time to check. This would be the one on top of the water pump right? Is it a 143 or 160 t-stat to be sure?
Old 06-16-2013, 04:13 PM
Spork's Avatar
Boat: Sporkcraft
^ according to engine nut it should have a 140° thermostat. I ran my 351w without a t-stat for a summer (mistake unknown to me when I bought my boat) and it ran at 140. I installed a 160° thermostat from http://www.bakesonline.com/detail.aspx?ID=844 and it operates right at 160-165 on my gauges.
/spôrk/
Old 06-16-2013, 07:36 PM
homer12's Avatar
Then any harm in running 140deg? I don't understand what damage or harm could be done by running a cooler engine. Looks like according to Bakes it may just be more efficient around 160deg
Old 06-16-2013, 07:40 PM
Spork's Avatar
Boat: Sporkcraft
Imo no problem, only issue I could see is if a heater is in play it probably won't work properly with a damaged or missing thermostat.
/spôrk/
Old 06-17-2013, 02:12 PM
Spork's Avatar
Boat: Sporkcraft
Location of thermostat...
/spôrk/
