Old 06-15-2013, 05:40 PM
Daubrey Daubrey is offline
Boat: 95 190 with LT1
Wrong Prop!
So I replaced my damaged prop on my 95 190, only to find out the hard way that I have the wrong handed prop! Why can't you, or what iswrong with simply running the boat in "reverse" until I can replace the prop?
Old 06-15-2013, 05:59 PM
88 PS190 88 PS190 is offline
Because reverse is a planetary drive. Essentially in forwards the trans just the clutches locking up to drive through to the prop.
When the reverse is engaged the transmission uses gears - hence the noise, the slower speed, and the fact that you never engage the throttle that far into reverse.
You're sunk until you get an LH prop.
Old 06-15-2013, 08:32 PM
John 3:16-18
Old 06-16-2013, 05:43 AM
petermegan's Avatar
lol.. made me laugh a little....
I'd run it in reverse until I could find a new prop... why not? reverse will get you there.....you may have to sacrifice some speed and skiing but it's doable...
Yea.....
Just don't get your missus to back it off the trailer Have fun
Old 06-16-2013, 08:11 AM
Boat: No Boat
What transmission is in your boat? If it is a velvet drive the reverse clutches are not the same as the forward. The reverse clutch pack has far fewer friction disc and I'm sure its not designed for high RPM use.
Sounds like a recipe for disaster! Seems like there would be a big chance of backing over someone if you happen to forget.
Tim
Old 06-16-2013, 10:30 AM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
Don't do it. The trans is not designed for full power in reverse and will fail if you run it that way. The ZF630 V-drive or the 630A gear reduction transmissions can full power in reverse but the ZF450D is not built for that.
Engine Nut
Indmar Marine Engines
Power to the Sport
Old 06-16-2013, 10:34 AM
Boat: No Boat
That's the way I figured it.
Larry, what year did Indmar switch over from velvets?
Tim
Old 06-17-2013, 11:09 AM
Quinten Quinten is offline
Boat: 1997 Crownline 182 (sold), 2012 Mastercraft X2
There was a brand that could get the same speed in reverse as in forward.
Don't remember the brand (sea ray maybe)
Old 06-17-2013, 11:25 AM
ahhudgins's Avatar
Boat: 79 S&S. 87 Prostar Powerslot. Present 95 Maristar 200VRS
You guys are making this waaaay to technical. Just flip the prop around and go ski.
Old 06-18-2013, 11:30 AM
xbot50000 xbot50000 is offline
Boat: 2003 X-9 MCX
We were docking on a really windy day, and had to put it in reverse pretty heavy to avoid some rocks. All was fine until we took it out the next time, after the wind calmed, and realized the heavy reverse had popped a freeze plug in the manifold. Easy fix, but it's a quick way to sink. Wouldn't recommended high RPM usage in reverse - unless it's an emergency.
