Old 07-25-2012, 01:20 AM
AZX9's Avatar
AZX9 AZX9 is offline
Boat: 2003 Mastercraft X9, MXC 350
DD center floor panel removal
The front section clearly has screws visible. On the back section covering the shaft seal I can't find any visible screws holding it down. Where am I missing them? 2003 x9
Old 07-26-2012, 04:54 PM
CCAnderson's Avatar
CCAnderson CCAnderson is offline
Boat: Mastercraft, ps209, 2001, 330,
Mine ('01 ps209) does not have any screws. I remove the gas springs, fold the engine cover back then lift up the panel by pulling up on the edge of the panel next to the hinges. A slight tug is all that is needed. the only thing holding it there is gravity the friction from the carpet.
Old 07-26-2012, 11:41 PM
AZX9's Avatar
Thanks I'll try that.
Old 07-30-2013, 10:46 AM
thorn210 thorn210 is offline
Boat: mastercraft 209 2003 mxc
did that work? I need to get to my shft seal also. Tried seaching and found this tread. have 03 ps 209. thanks!
Old 07-30-2013, 11:00 AM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
Yes....
Just a friction fit. I just put several blankets on the back deck and roll the cover and lower panel on it. It's not exactly light weight. Two people would be required if you want to lift it out of the boat and set it on the ground.
The important thing when putting it back in is to make sure the floor panel is tight against the back wall. Otherwise your latch in the front may not fit correctly when lowering the cover. There are no pins or guide points for alignment.
Old 07-30-2013, 07:58 PM
johnstonrm's Avatar
johnstonrm johnstonrm is offline
Boat: 2002 X-30 330hp
Had a major struggle removing the floor panel on my 02 X-30 to thread new steering cable. Found using mild dishwasher soap at seams helped greatly.
