Old 06-14-2013, 11:56 PM
mrhodes12 mrhodes12 is offline
Boat: 1999 Prostar 205 LTR
Send a message via Yahoo to mrhodes12
Vibration
Took the boat out for the second time this summer and noticed a vibration at 2000-3000 rpm. I figured a bent prop, so switched to a new prop, problem still there. Any ideas of cause? Bad fuel, fuel pump, tranny problems? Anyone else had problems such as this?
Thanks Mitchell
Mitchell
Old 06-15-2013, 09:46 AM
bturner2's Avatar
bturner2 bturner2 is offline
Check for play in the thrust bearing. Could also be alignment.
Old 06-15-2013, 10:39 AM
check true-ness of drive shaft - if prop was struck - shaft may have some wobble to it.
Old 06-15-2013, 10:44 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Ha you said wobble...
http://www.youtube.com/watch?v=UH5hUULu4Nk
/spôrk/
Old 06-15-2013, 12:01 PM
Originally Posted by [email protected] View Post
lol... too funny
Old 06-17-2013, 12:38 AM
john jones john jones is offline
Boat: 2002 Xstar
I didn't believe it myself. Everyone said that you should be able to spin your prop with two fingers. I never could. On my last two boats I always had to use two hands. I figured that was the way it was. I also had a vibration at 2000 rpm, I pulled my prop shaft and it was bent!
After I had the shaft straightened back to .004, replaced cutlass bearings, installed the shaft and believe it or not I could spin it with two fingers! Vibration at 2000 rpm was gone.
I would look towards your prop shaft.
Old 06-20-2013, 12:26 AM
After some research I drained the gas tank added sea foam and fresh non-ethanol gas, the boat ran much better, I know I will be adding a ethanol treatment from now on. Thanks for your replies
Mitchell
