Old 06-09-2013, 10:31 PM
Miss Rita's Avatar
another PS 205 question
despite being a boat owner for 22 years, and owning a MasterCraft for four years, it appears I know nothing about 205's! My '92 has an in-floor storage compartment forward, with a small connection to the bilge. All the nasty bilge water washes forward, but doesn't return, even if I raise the tongue of the trailer as high as possible. It looks like the hole could be plugged with some kind of threaded plug? Am I on the right track?
Old 06-09-2013, 10:39 PM
Table Rocker's Avatar
I bought a rubber drain plug for mine. Finding the right size was the hard part. 5/8"
'96 ProStar 205 SD LT-1
Old 06-09-2013, 10:53 PM
willg willg is offline
Boat: 02 X-Star
I think the plug looks like this:
And is sold here (I'm not sure what the deal with multiples of 5 is):
search for "Plug - Bailer"
http://www.charlotteskiboats.com/mastercraft_parts.cfm
Old 06-09-2013, 11:34 PM
Miss Rita's Avatar
thanks for the help. Since it's not threaded, I think I'll mosey on down to Ace Hardware tomorrow, see what they've got.
Old 06-09-2013, 11:39 PM
etduc's Avatar
etduc etduc is offline
Boat: Something else, DD 2004 red/white/black
Academy has them, also.
Ayyyy!
2004 Red/White/Black something or other.
Formally, 1994 RED Mastercraft 205, Chevy 5.7 TBI.
Old 06-09-2013, 11:41 PM
Dynamite Spike's Avatar
Dynamite Spike Dynamite Spike is offline
Boat: 1996 Prostar 205
I bought one for my '96 ProStar at Bass Pro Shops. I'll look for the packaging tomorrow so can let you know the correct size.
Old 06-10-2013, 08:16 AM
bkblaida bkblaida is offline
Boat: MasterCraft PS 205 1997
We have the same rubber plug in our 205. Problem is the drain hole is not flush with the bottom of the storage locker/cooler so once you get water in the locker you always have water until you vacuum it out or dry with a beach towel.
Old 06-10-2013, 09:37 AM
Miss Rita's Avatar
I figure I'll be drying the locker frequently. I have an old shop vac that I use for water only, so it won't be a huge problem.
Old 06-10-2013, 09:40 AM
A car wash sponge works like a champ.
Old 06-10-2013, 09:58 AM
cal69 cal69 is offline
Boat: 1992 PS 205, 351 HO 1:1
Though replacing the plug may keep water from running though the divider, the problem is that water runs past the divider between the bilge and the ski locker. There is a plate under there that is held on by 4 screws. You can get to it by removing the four screws holding down the small section of flooring surrounding the ski pylon. Once you remove the divider plate underneath, you can clean it and reapply sealant around the sides and bottom and hope for the best. I did mine, but sometimes still get a little water in the ski locker. I only keep oars in there because it gets damp and is hard to keep 100% dry.
Hope that helps.
