Old 06-07-2013, 12:12 PM
slink976's Avatar
slink976 slink976 is offline
Boat: 2006 MasterCraft X2
Send a message via AIM to slink976
Ballast
My port ballast can empty but not fill, Anyone seen this before? Sounds like it's running but not filling.
When you go into court, you are putting yourself in the hands of 12 people who weren't smart enough to get out of jury duty.
Old 06-07-2013, 12:16 PM
ttu's Avatar
ttu ttu is offline
have you checked the impeller?
Old 06-07-2013, 12:43 PM
Boat: No Boat
Pinched or clogged vent line?
Tim
Old 06-07-2013, 01:56 PM
slink976's Avatar
I thought impeller myself but why would it pump out?
Old 06-07-2013, 01:57 PM
Boat: No Boat
Weak fins?
Tim
Old 06-07-2013, 04:40 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Maybe it took a good set in that direction. Now the resistance is less in that direction but possibly stronger in the other. Just a possibility.
Old 06-07-2013, 05:29 PM
treiter's Avatar
treiter treiter is offline
Boat: 2009 X-15
I had a similar problem that was occurring randomly. I just pulled the stock yellow impellers out and they were definitely bent such that they were favoring one direction. Probably in the emptying position since that would have been where they sit each winter. Put in new green impellers and hope to test next week.
Old 06-07-2013, 05:37 PM
Boat: 2006 X30
And the other two fill just fine? I was thinking bad check valve (or valves) on the "empty" hoses, but if the other two are filling normally then check valves should be ok. Blow into the "empty" port on each side of the boat to be sure the check valves are ok. If you can blow air into it then the check valve is bad and you won't get enough vacuum to draw water - but because they all feed off of the same manifold, a bad check valve should affect all three equally. Are you positive the pump is running when switched to "fill"?
