Old 06-05-2013, 09:19 PM
roush611 roush611 is offline
Boat: 1983 Mastercraft S&S
Help with 4160 Rebuild
I am in the process of putting my 4160 back together but I came to a hurdle. I found a part in the bottom of my soaking tray that fell out of something. This part is also included in the rebuild kit from holley. I have no idea where it goes please help ha ha...
Metal object pictured...
Old 06-05-2013, 09:34 PM
John 3:16-18
Old 06-05-2013, 09:37 PM
Boat: No Boat
That looks like a needle valve from a float assembly ..
Have a look on PDF file page 17/21 at the view box #2.
I am not certain....
Na, the needle for the float would have a grove and a wire hook on it so it could attach to the float. That's how the float pulls it up.
Tim
Old 06-05-2013, 09:45 PM
Its not part of the float assembly as stated above those needles have a wire through them.
EDIT: Figured it out. It is the pump discharge needle valve. It goes in below the squirter. Thank you for the diagram Cloaked!!!!
Old 06-19-2013, 10:34 PM
pbgbottle's Avatar
pbgbottle pbgbottle is offline
Boat: 1988 tristar 190
quick question what are those square shaped cork pieces used for ?
in the top right corner of your photo
1988 mastercraft tristar (open bow).
Old 06-19-2013, 10:48 PM
Boat: 1987 ProStar 190
I could not find a use for those square cork pieces when I rebuilt my 4160. Actually, I had at least 7 or 8 parts in there that I couldn't find a place for.
Old 06-19-2013, 11:15 PM
No idea! They put a lot of extra parts in the kit for some reason.
Old 06-19-2013, 11:24 PM
There is some overlap where more than one carb application will be serviced by a carb kit. Spare parts left over in the kit isn't necessarily a bad thing. Spare parts left over in the carb basket is usually a problem.
Old 06-19-2013, 11:28 PM
pbgbottle's Avatar
thanks
Old 06-20-2013, 12:57 AM
T-Rager T-Rager is offline
Boat: 2004 ProStar 197, MCX, Sammy Duvall
That the accelerator pump discharge check needle. It is item #82 in the parts diagram. It installs in the pump discharge channel beneath the pump discharge nozzles.
