Old 06-04-2013, 09:47 AM
Mastercraft13's Avatar
Boat: 2013 X-10 6.0
Originally Posted by onewheat View Post
I didn't think PnP was available anymore on the 13's?
X-star is the only model for 2013 that you can get from the factory with PNP as far as I know.
Old 06-04-2013, 10:13 AM
Nick911's Avatar
Nick911 Nick911 is offline
By PnP I mean owners that have had extra ballast plumbed into overflows.
Old 06-04-2013, 10:18 AM
FourFourty's Avatar
Originally Posted by Nick911 View Post
Man I should have bought a G23...please tell me this isn't a repeat of 2012. Is it too much to ask to have a ballast system that works?
You plumbed in extra bags.... you have to get your timers dialed in, it is no big deal. If your timers are set too low, because of the extra bags, it is going to leave water in the tank. It will think it is empty because of the times that you have set for empty and fill. It uses those times as a guideline and also checks the sender readings once in a while to verify levels.
It took me an hour or so of changing times, and setting up the appropriate fill/empty times after I added the bags. It works perfectly now.
Old 06-04-2013, 10:56 AM
Nick911's Avatar
Nope it's showings sporadic levels regardless of bags. I confirmed on trailer tanks were empty day before. Get on water it tells me my tanks all have a different percentage. I bring them back to zero, turn ignition off, turn it back on, and one tank is showing 100%. Drain it, turn off ignition, then next tank is showing 20%.
The KGB is also acting up and it has no bags.
Nick911's Avatar
Anyone have a contact # for MC?
Old 06-04-2013, 05:17 PM
Lucky26 Lucky26 is offline
Boat: 2013 X-25 6.0 Pro Package
423-884-2221
Old 06-05-2013, 10:43 AM
Nick911's Avatar
Dealer told me to disconnect batteries for 10 minutes then reconnect. Well give that a try today see if it resets system.
Confirmed with dealer there are senders and timers and they work together to determine ballast levels.
Might be a programming/software issue.
Old 06-05-2013, 05:48 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
can you not tell if your tanks are empty or not based on the sound it makes when you have the pumps on drain? i can always tell on my 15 with pnp.
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 06-05-2013, 08:11 PM
Nick911's Avatar
You can generally tell when they go from full to empty as the pump surges, however, you cannot hear this while underway or while you are revving at 1500 rpm as per ballast pump specs.
Also, the point is, my indicators should work.
Old 06-05-2013, 08:28 PM
MC25's Avatar
well I understand. just making sure they aren't actually filling up with water. and if I'm not mistaken the pumps get even louder when you rev it up, no? never revved my boat to 1500 to fill the tanks and I've been fine for three years. I understand you're pissed, but talking down to me like i have no clue what I'm talking about isn't going to help you either.
-Aric
1985 S&S- For Sale
