Old 05-29-2013, 12:21 PM
501s's Avatar
501s 501s is offline
Boat: 2013 X-30, 6.0L, 2500lbs of Ballast, 650lbs of Lead.
Automatic Speed Based Volume Control of your Iphone
So I was doing some research and I found a new APP out for the iphone that lets you control the volume based on speed. I setup a separate profile for surfing and wakeboarding and so far it works awesome. Slow the boat down and the volume drops to a pre-set level, speed up above a certain speed and it raises up to a louder volume that you set. Very easy to use and only $.99. The speeds are pre-set so using the km instead of miles works a bit better because surf speeds are so close to 10mph and wake speeds are close to 20mph, so I set them to turn up at 10km and 20km instead. A decent use of a buck! The app is called Vol Adjuter (I think it's actually a spelling mistake). ONLY drawback is you have to use Bluetooth or the headphone jack, you can't use the outputs from an ipod cable. I added Bluetooth in my boat so this is perfect for us. Here is a link.
https://itunes.apple.com/sg/app/volu...547012209?mt=8
Old 05-29-2013, 01:14 PM
WC205's Avatar
WC205 WC205 is offline
Boat: 2004 Prostar205v
I'm assuming it uses its own GPS to figure out how fast you're going. ??
Nevermind. Read the description closer.
Old 06-02-2013, 07:54 PM
willg willg is offline
Boat: 02 X-Star
If you are looking to spend 180x as much, I found this product by accident. I really like the idea, but it's way too $$ for me to justify.
http://www.wakeblaster.com/products/WakeBlaster
Old 06-28-2013, 03:09 AM
StrmChzr StrmChzr is offline
Boat: 2005 XStar
Great find, 501s!
Going to give it a try this weekend.
Old 06-28-2013, 03:29 AM
VP46's Avatar
VP46 VP46 is offline
Agreed this is awesome if it works as you say!
fyi - if you search for apps from your phone it is called "Volume Adjuter" - they appear to have spelled Adjuster as Adjuter...
Old 06-28-2013, 03:36 AM
501s's Avatar
Used it tonight for surfing. Worked great.
Old 06-28-2013, 05:08 AM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Thanks, will try it out this weekend. My stereo has some auto volume control as well, this one seems to be better... Kinda like the delta between perfect pass and zero off...
Old 06-28-2013, 06:30 PM
88 PS190 88 PS190 is offline
I totally read this wrong:
Automatic volume based speed control off an iphone.
Damned, I was thinking someone had cracked the secret to using their smart phone to do speed control.
Old 06-29-2013, 02:46 AM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Friggin' apps killing perfectly good hardware solutions! Oh well!
'07 Navy Blue X2 MCX
Ballast Timer Reprogramming Info
Old 07-05-2013, 12:37 AM
Seano Seano is offline
Boat: 2014 X30 GEN2
Sweet thanks
