Old 05-30-2013, 12:28 PM
JGWIN55 JGWIN55 is offline
Boat: 2010 Mastercraft X25
transom stereo remote fail
After turning on my radio, it kept turning the volume up to Max by it self. A savvy friend traced it to the rear remote which was full of water and causing the stereo to turn it self up.
I have only used this (used) boat 3 times and this remote is full of water and failed. Has anyone ever had this happen and whats the best way to fix/replace?
Thanks,
JG
2010 X-25
Old 05-30-2013, 12:40 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
You can buy a new remote on ebay. Search for clarion marine remote. Count the number of pins in the plug from the old remote. If its 6 then you need the cmrc2-bss remote, if its 8 then you need the MW2 remote.
Remove the old one by loosening the bracket behind it. The cable from the remote to the stereo is most likely fine. Just plug the new one into the existing cable.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 05-30-2013, 01:09 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
My 2010
X-15 transom remote stops working too. Not sure what caused it. It will occasionally stop working after a long day on the lake. But after it dries out it works done!
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 05-30-2013, 02:05 PM
EarmarkMarine's Avatar
Boat: TBD
When a remote control is mounted lower on the transom, as you come to an abrupt stop the remote may be washed or even submerged for a moment due to the backwash with an element of pressure. Also, remote controls have no tolerance for any degree of pressure wash.
David
Earmark Marine
www.earmarkmarine.com
Old 05-30-2013, 08:58 PM
Mastercraft13's Avatar
Boat: 2013 X-10 6.0
I opted out of this feature on my boat this year, just because I thought this could happen. Electronics hate water.
stereo issues, x-25
