Old 05-30-2013, 11:20 AM
Dino Don's Avatar
Dino Don Dino Don is offline
Boat: mastercraft 190 1987 351 Indmar
Rudder question?
I hit my drive line with an under water log and wiped out the drive shaft, prop and bracket and my rudder looks ok visually but when I move it side ways it seems to have a little too much motion. Side to side or wobble in the mount should be how much? I'm guessing mine has .030 plus movement. Boat has 675 hours on it and for an 87 thats not a great number of hours so I wonder if the hit has made an add'l issue for me.??? Thanks for any thoughts.
Old 05-30-2013, 11:29 AM
88 PS190 88 PS190 is offline
There is a packing/gland nut on most rudder boxes, should lock down some of that motion.
Old 05-30-2013, 11:35 AM
Dino Don's Avatar
Have you ever checked yours to see how much motion is in it?
Old 05-30-2013, 11:37 AM
Boat: No Boat
I've never seen a packing gland nut on a rudder. It's normally just two rubber seals on the older models or a big seal on the top of the newer ones and then the tiller arm on top of that.
You may want to pull the rudder and check it with a straight edge. Look for cracking the gel coat around the rudder housing. If nothing looks out of wack I would just repack the rudder with grease and make sure the tiller arm is tight.
Tim
Old 05-30-2013, 11:56 AM
Dino Don's Avatar
Visually it looks ok it was just the loss motion that I was concerned about. I had never checked it before it might have been there all a long and I just didn't realize it. I had no leaks or water coming in the floor of the boat so I never checked it.
Old 05-30-2013, 12:23 PM
Boat: No Boat
My rudder moves around too. I made a quick video just now. It may take a couple of minutes to process but here you go.
http://www.youtube.com/watch?v=m6Kv2-I_FFM
I've never hit anything with it and I grease it each year. I still need to get that done this year so this might motivate me to get that done.
Tim
Old 05-30-2013, 02:47 PM
pmikler's Avatar
pmikler pmikler is offline
Boat: 2006 x30
Plus 1- mine has some slight play as well.
Old 05-30-2013, 10:02 PM
Dino Don's Avatar
That's about the same amount I have in mine so it maybe just fine. Thanks for the video--had I not hit it I wouldn't have thought about it. This is what makes this forum so good
Old 06-01-2013, 02:54 PM
Dino Don's Avatar
Well thanks to the log I hit my rudder is bad--that means everything under there is bad. Anyone know why I shouldn't use Discount Marine instead of mastercraft parts to fix this boat??
Old 06-01-2013, 11:58 PM
Jerseydave's Avatar
TT Hero
Doesn't OJ props sell rudders and rudder ports?
Does your insurance cover underwater hits? I clobbered my gear back in the 80's on my Ski Eliminator and Insurance covered everything.
I was njskier on here.
