Old 05-28-2013, 12:20 PM
SSMoose SSMoose is offline
Boat: 1983 Stars and Stripes PowerSlot
83 S+S sticky steering- replace cable?
I finally got the boat in the water last week, finding the steering awful. It is sticky and does not go as far left as right. I am guessing that I should just replace the cable. I don't want to wreck due to steering (un)responsiveness. I know you guys will give me the best advice.
Old 05-28-2013, 12:34 PM
keith3613 keith3613 is offline
I have a 1984 S&S. There is a guide tube clamped in front of the rudder on the floor. The inside of the tube can rust and the cable shaft will rub and bind. Remove the tube clean it and repaint it inside and out with something like POR-15. That may be part or the entire problem. You can tell when you get it apart (4 bolts, easy).
Old 05-28-2013, 12:36 PM
ted shred ted shred is offline
Boat: Mastercraft,powerslot,1983,pleasurecraft 351
You probably do need to change the cable. When I replaced the one in my 83 back in 2002 the part # the MC dealer sold me was 11110A14. Hope this helps.
Old 05-28-2013, 12:47 PM
Thank you for this info, Ted. I like to know the what first, then buy parts. Is this a project I can do in the water or do I need the boat on the trailer?
Old 05-28-2013, 12:53 PM
barefoot's Avatar
barefoot barefoot is offline
Boat: '83 Stars and Stripes
Hold off on replacing the cable until you use it a bit this season. Most likely, there is some lube build-up that's making it hard to steer. Whenever I pull mine out of the barn, it takes a day or two to get everything loose again.
Hello, my name Ryan!
Old 05-28-2013, 07:17 PM
roush611 roush611 is offline
Boat: 1983 Mastercraft S&S
Well you can do it on the water but it would be a lot easier if you did it on the trailer. The bolt that goes into the rudder is not the easiest thing to get to.
Old 05-28-2013, 08:18 PM
LGP LGP is offline
Boat: 1985 MC SS
zirc fitting
If you have over filled the zirc fitting at the top side of the rudder inside the boat, this too will give you tough steering conditions. If it is over filled.. undo it and release some of the pressure and your problem will possibly go away. Just an idea for you to consider.
Old 05-28-2013, 08:43 PM
88 PS190 88 PS190 is online now
LGP that zerk should not have that ball bearing, the ball prevents grease escape - which will lock up the steering.
Old 05-28-2013, 08:44 PM
Better to do on a lift or trailer - big trick is to use a rope so that you can pull the old one back out swap the rope to the new one and pull the new one back in.
Old 05-29-2013, 09:43 AM
Many thanks to all who have replied! This gives me more faith that I can figure this out and fix it correctly. Now to get back to the old tug.
