Old 05-28-2013, 10:17 AM
magnum's Avatar
magnum magnum is offline
Boat: Mastercraft X-Star 2006 L18
Oil Bath Bearing Seal
Has anyone replaced the oil bath wheel bearing seal or where do you buy one? Its for a 2006 Mastercraft Trailer.
Mastercraft 06 X-Star 8.1L
Old 05-28-2013, 10:58 AM
bkblaida bkblaida is offline
Boat: MasterCraft PS 205 1997
Should be available from your local dealer or any auto parts store. The number on the seal will allow the auto parts store to cross reference. Make sure to tell them it is an oil seal as they are different from a grease seal.
Old 05-28-2013, 08:26 PM
kyfooter's Avatar
kyfooter kyfooter is offline
Boat: 2013 197 WTT / 1992 Barefoot Sanger
Yes. I had to buy them from a dealer. At the time, oil bath bearings where rare and the local auto parts stores could not cross reference them. That was a few years ago though, so hopefully from a convenience factor they are now able to be cross referenced.
Old 05-28-2013, 11:48 PM
magnum's Avatar
Went by Dealer today and he told me that the 06 came with a Plastic cap with the see thru glass so it usually cracks before the seal blows out when it gets hot and that is hopefully what happened in my case, He sold me the aluminum caps for them now so they are a lot better than the plastic caps that were used in the 06 and earlier trailers
Old 06-02-2013, 08:07 PM
willg willg is offline
Boat: 02 X-Star
My mastercraft trailer has UFP components. The oil bath bearing system is manufactured by UFP under the name Trailer Buddy. I believe the system that mastercraft used on my trailer (2002 year) is the GOLD system, not the VAULT. I like the window, it makes it easy to fill the oil and check the level. Here's where you can buy the caps and other parts. I had to order a new brake disc, and got a better deal calling them.
http://www.pacifictrailers.com/Bearing-Protectors/
also some information on UFP:
http://www.ufpnet.com/Axles/tabid/55/Default.aspx
Old 06-02-2013, 08:16 PM
Boat: 02 X-Star
double post
Old 06-20-2013, 02:14 AM
JMan JMan is offline
Boat: Striper 07 200 Yammy
Oil Bath Bearings
I installed the Kodiak SS disc brake system on my EZ loader tandem trailer with Pro lube oil bath system. One of the (blue) plastic caps separated where the cap meets the threads. I've read where some have replaced their plastic caps with metal ones with a window. Mine are 1.980". Where might I find the metal caps please. Appreciate any help I can get.
Old 06-20-2013, 09:12 AM
magnum's Avatar
http://www.trailerpartsdepot.com/ite...ic=OBC-2441AL&
This is a site that has the reliable brand oil bath caps, might have what you need
Old 06-20-2013, 09:27 AM
meg meg is offline
Boat: mastercraft x30 2006 mcx
MAGNUM- I had the same issue with my 06 trailer and I called reliable and they sent me the aluminum caps free (great customer service) replaced them several years ago and no problems since (knock on wood)
Old 03-16-2014, 09:21 PM
monsterwake's Avatar
monsterwake monsterwake is offline
Boat: 2018 NXT22
I have replaced my caps but I stripped one of the fill hole caps. Since I think they are copper I tried to go to the hardware store to get a new one. Wrong. All I could find was a 10MM fine threaded copper cap in the air compressor area but it is a little too long and I cannot put the dust cover on with the wheel. Does anybody know where I could find the correct threaded cap for this filler whole?
