Old 06-03-2013, 11:18 AM
j4rowell's Avatar
j4rowell j4rowell is offline
Boat: Row Boat w/ 5HP Motor for tubing
2009 X2 - 350 MCX Power Loss & High Idle
I'm in need of some help.
When the boat is under load (ie surfing/wakeboarding) the engine will cut out every so often. The boat will not stall, but just return to an idle. After shutting the boat off for about 3 -5 minutes it seems to run fine for a bit but will eventually happen again.
Another issue I am having which I'm hoping is related, is sometimes the boat will idle high/rough.
Any suggestions?
Old 06-03-2013, 11:21 AM
snork snork is offline
Boat: 07 xstar
how many hrs?
Old 06-03-2013, 11:34 AM
CantRepeat's Avatar
Boat: No Boat
Any suggestions?
When it idles back down are you getting a buzzer and a check engine on the screen? Is your oil level low?
Tim
Old 06-03-2013, 11:43 AM
j4rowell's Avatar
Originally Posted by snork View Post
how many hrs?
394 Hours
I am getting a "Check Engine" screen when the power cuts out but when the idle issue happens there is no "Check Engine" screen.
Thanks for the questions guys! Keep them coming!
Jerseydave's Avatar
TT Hero
Assuming the oil level and oil pressure are good, and the boat is not overheating, the next thing to check is fuel pressure. If you can check it when it loses power that would be best.
Sounds like your fuel pump is failing when it gets hot, then you shut it off for a bit and it cools down enough to start working again. Don't let your fuel tank go below 1/4 ever.
I was njskier on here.
Old 06-03-2013, 11:46 AM
j4rowell's Avatar
Would the fuel pump be related to the idle issue?
Old 06-03-2013, 12:04 PM
CantRepeat's Avatar
Boat: No Boat
Yes fuel pump/low pressure could result in a poor idle. It's a pretty easy check.
http://www.napaonline.com/Catalog/Ca...336_0361126168
The issue with your boat, MEFI 5 ECM, is you will need a semi expensive scan tool or PC software and cable to pull the codes from it.
Tim
Old 06-03-2013, 12:16 PM
j4rowell's Avatar
Great. I'll check the pressure. What's the operating range for this pump?
Can someone supply a cross reference number to the fuel pump for my motor so I can purchase from the local auto parts store (ie NAPA, AutoZone, Advance Auto, O'Reily's or Pep Boys)?
Old 06-03-2013, 12:48 PM
CantRepeat's Avatar
Boat: No Boat
Fuel pressure should be between 55-62 from idle to WOT.
A couple of threads about fuel pumps.
http://www.mastercraft.com/teamtalk/...ad.php?t=24965
http://www.mastercraft.com/teamtalk/...ad.php?t=25783
Tim
Old 06-05-2013, 11:53 PM
Seano Seano is offline
Boat: 2014 X30 GEN2
check for exhaust manifold elbow sensor update for the 2008's. I had many issues with these #$%# sensors. Perhaps your 2009 was a 2008 engine. Basically the sensors are deleted for emission as they are faulty unless you live in California off course. My boat went into limp mode at a governed rpm. I did not have the idling RPM issue. good luck
