Old 06-10-2013, 08:17 AM
bturner2's Avatar
bturner2 bturner2 is offline
I worked in a body shop while going to school and learned an important lesson while there. When working on any restoration project always use the least abrasive solution possible to achieve the desired result. Not saying you won't have to sand or go to 400 to get there but I would be working my way into it rather than doing the entire boat with it to start with. You'd be amazed what rubbing compound and a rotary buffer can do (good and bad). It's all going to depend on the surface condition.
I typically tackle these projects as "long term" goal type of projects and will start in one area making my decisions on an area by area basis. Restore one area, have a beer while reflecting on what went well and what might have worked better then move on to the next. If all goes well you'll be somewhat of an expert on gelcoat restoration by the time you're done.
Old 06-15-2013, 02:05 AM
NWMike's Avatar
NWMike NWMike is offline
Boat: 1993 Mastercraft Prostar 190, 285 hp HO, 1:1
I am in the process of knocking down some oxidation/fade on the transom of my boat since I'm changing out the decal to a newer version. I went with 1000 grit and wouldn't go any more than that. In fact, #1200 would have been best to start with. Will follow with #1500 and then start with the compounds. This pic is at #1000. More than enough to cut through the worst of it.
Old 06-18-2013, 04:11 AM
NWMike's Avatar
Here is after I went to #1500, then polished it with MeGuiars #2, then to an orbital polisher with #7 and work that a little while. Could easily start at #1500. Got it back to such a good gloss I put my newer transom decal on.
