  #31
Old 07-02-2013, 02:08 AM
jessejames jessejames is offline
Boat: 99 Mastercraft Prostar 205 VRS
Anyone know if you can run your boat without the MDC plugged in?? Obviously the gauges won't work.
I got one from Medallion, but I forgot it at home and already drove up to the cabin for the week. So just wondering if I can drive without it for a day until my wife comes up and can bring it.....Anyone try it??
Also...check this thread out. http://www.themalibucrew.com/forums/...ntroller-help/
It sounds more feasible that the air leak allowing water up to diaphram is cause for failure than the freezing. It just doesn't make sense why some years and some boats are fine with not draining, and then 1 year you aren't. It also makes more sense that the tubes are full of air and the air gets compressed by the water at the pickup. This would also mean that they drain on their own and if they didn't, then the MDC still would not be affected.
Question is now....Why do they leak, and how do you prevent that? Especially if I'm putting on a new one, how do I know the leak is fixed and not going to happen again?
Old 07-02-2013, 06:37 AM
They leak because they DON'T always drain on their own. It's not a thin tube going from the transom to the dash, there's a larger brass cylinder called a ballast that kind of softens the pressure from the pitot(s). If it isn't drained, and this IS part of general maintenance whether anyone wants to think it should be necessary or not, the water can eventually fill the ballast. When that happens, the thin diaphragm in the speedo or MDC fails and at that point, there's nothing keeping it from working its way to the MDC or speedo. The part in bold type above is accurate WRT the principle behind these.
The only way around this is to use an electronic pickup that never sends water to the speedo or MDC.
The only way to prevent this is to purge them of water, periodically. Since it takes almost no time, I don't understand why this is such a common problem. Blow out the lines from the front, connect the MDC and it will work as long as the diaphragm in the MDC is intact. Until you install the MDC, stick a golf tee in the end(s) of the lines so water doesn't fill your shoes (drip on the floor under the dash).
You should be OK if you don't have the MDC.
Old 06-29-2015, 03:19 PM
So...this just happened to me again. First time the boat was in the water this year and bam, water coming out of the MDC box right where the pressure sensors are again! It's partially my fault for not doing what the last post suggests. I live out of state now and just trust a shop to do my winterizing which apparently isn't enough!
Anyway, the point of my posting is to inform that you can no longer buy Direct from Medallion. I contacted them and they said I HAVE TO buy from MasterCraft due to the "current policy" they have now and I can't buy direct. I called Midwest MasterCraft and they are $660!!! Thanks for the $460 mark up MC, not like you don't rake us over for enough already. Guess I'll be paying for your poorly designed Gauge system again.
Old 06-29-2015, 03:26 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
You could replace with a set of mechanical gauges if you're handy.
Look for a thread about it here.
Edit:http://www.mastercraft.com/teamtalk/...s+replacements
Keep skiing!!!
Old 06-29-2015, 10:00 PM
If a shop winterized your boat and didn't drain the pitot lines, take it back to them and have them pay for the repair that they caused. THEY were supposed to do that, regardless of any protest they may offer.
