Old 06-05-2013, 04:29 PM
John 3:16-18
Old 06-05-2013, 04:31 PM
O-ring experience(s)......
Be careful on how you place the fuel tube back in the seated area. The inclination is to put the o-ring on the fuel tube and push it into it's respective seating area. The o-ring can disconfigure if you are not very careful and gentle with placing the tube in the seat. Put it in easy, use a little lube (soap suds?) and make sure you visually confirm the o-ring did not get discombobulated when installing (both ends). There is one of several opportunities to rush with reassembly and have a leak...
Been there more than once.....
Oh sure, get all technical on us.
Really good point.
Old 06-05-2013, 04:52 PM
Boat: 1987 ProStar 190
I had a similar o-ring issue with my fuel transfer tube. The end at the secondary was not seated well and was spraying fuel all about.
Cloaked, what would be the symptom of a leak in the tube referenced above?
Replacing old o-rings is very important. If you didn't get them in your rebuild kit, either they missed putting them in (unlikely but possible) or you had the wrong kit.
Now that you mention it, I may very have had those o-rings in the kit but thought they were too small to be used on that brass tube. Oh well, I still have those o-rings so this is an easy fix.
Old 06-05-2013, 05:10 PM
John 3:16-18
Old 06-05-2013, 08:50 PM
pbgbottle's Avatar
pbgbottle pbgbottle is offline
Boat: 1988 tristar 190
Thanks for the info. I hope the orings are there. I ordered the same kit. That was the right kit for your carb And mine
We had the same model number.
1988 mastercraft tristar (open bow).
Old 06-20-2013, 10:53 PM
pbgbottle's Avatar
quick question for u catamount did u change your pump cam ?
yours is sorta red mine is white. and this info i found said it should be pink see pics with 2.5 power valve. .
just curious because i rebuilt my carb and off idle on tip in . it dumps a ton of fuel in there almost floods chokes my engine. otherwise she runs fine. i just picked up some cams and a 2.5 power valve gonna try and replicate the oem specs from back in the day .
any info would be grealty appreciated. i think the PO must of changed mine
Old 06-21-2013, 12:16 AM
I didn't touch the AP cam. I figured that whatever was there was working (and it was). Also, your spec sheet lists a 2.5 power valve but Holley sent me a 5.5 in the renew kit. I assume that Holley knows what it's doing so I used the parts in the kit.
Let us know how it works out for you though.
Old 06-21-2013, 12:27 AM
I have come across a number of applications where Holley uses the 5.5 power valve in the 240 hp version and the boat has run quite well so equipped.
Old 06-21-2013, 12:29 AM
Have you tried to go to a shorter stroke with the optional hole to back off on the amount of fuel being squirted? I assume your choke is opening fully.
Old 06-21-2013, 02:43 AM
pbgbottle's Avatar
i never noticed another hole . i will have to look ,any pics of this for reference ,
