Old 05-18-2013, 10:14 PM
LGP LGP is offline
Boat: 1985 MC SS
swim step is loose
1985 SS. Swim step is loose and the 2 upper bolts on both sides are stripped. Can these be reached by taking out the fuel tank or are they under the floor... again these are the upper bolts.
Thanks to all of you for any thoughts!
Old 05-21-2013, 12:02 AM
roush611 roush611 is offline
Boat: 1983 Mastercraft S&S
On my 83 you can't get to the bolts with the tank out. You have to cut the fiberglass too.
Old 05-21-2013, 11:29 AM
83MC 83MC is offline
Boat: 1983 S&S PowerSlot
Platform Bracket Through Bolt
I just through bolted the top two on each platform bracket and used aluminum plates.
You will have to take the tank out. However, you do not have to cut the floor out. I drilled from the outside in and the holes are just above the floor. I will see if I can round up a picture or two…
Old 05-21-2013, 11:38 AM
LGP LGP is offline
Boat: 1985 MC SS
that would be great! thank you
Old 05-21-2013, 12:00 PM
Link to pictures
Link to pictures...http://www.mastercraft.com/teamtalk/...871#post688871
Old 05-21-2013, 09:39 PM
sethro's Avatar
sethro sethro is offline
Boat: 1998 Malibu Echelon and 1985 Stars and Stripes
Here is a link when I did just this to my 85
Platform Bracket Backing Plates
Old 05-22-2013, 05:43 PM
LGP LGP is offline
Boat: 1985 MC SS
whoever did the work before cut into the floor and did not replace it. I was going to foam in the area which is 3 x 4 inches and then glass it and resin tight. your thoughts?
d
Old 05-22-2013, 05:55 PM
sethro's Avatar
I would definitely seal the hole, and that sounds like a good plan to me.
