Old 05-17-2013, 10:39 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
2012 X30 1100 rear lockers
I added these and fill with a hard plumbed super Sacr and a for future use, also plumbed piggy back on the hard tank.
I'm still working on dialling it in will post wave with rider pics tomorrow.
Old 05-18-2013, 10:31 AM
Boat: No Boat
Do you have any weight up front? If so I would suggest lowering the amount you do have. I think you'll get a better curl and a bit more push.
Tim
Old 05-20-2013, 09:13 AM
Boat: 2012 X30, 6L
Not much up front. Still making small adjustments in speed with all the weight in the rear corner and under port or sb bench. Perfect pass seems pretty stable with CS 750, KDW 180 and NN 120.
Old 10-02-2013, 12:26 AM
Seano Seano is offline
Boat: 2014 X30 GEN2
So is the 1100 sac a good fit or should i stick with the 900's?
Old 10-02-2013, 12:38 AM
501s's Avatar
501s 501s is offline
Boat: 2013 X-30, 6.0L, 2500lbs of Ballast, 650lbs of Lead.
I have 750s in the rear and when full, there isn't too much extra room, but if I was doing it again Id go with bigger bags.
2013 X-30, 6.0L with 2500lbs of ballast and 500 lbs of lead.
Old 10-02-2013, 07:09 AM
Boat: 2012 X30, 6L
I'd go 1100's again. However a few tips...
1. Reinforce the locker panel that sits between the engine and the bag. When filling the surf side 100% and then the opposite side at 50-70% there is a fair amount of flex in the panel.
- the little U shaped aluminum channel that has only on screw in it needs a second screw to help it avoid spinning out of place and subsequently the bag and panel could find their way into the engine compartment.
- I plan to add more strength to the panel and the supporting structures down the road.
http://www.mastercraft.com/teamtalk/...ad.php?t=55188
2. Consider that newer bags (Ronix 8.3) that may let you transfer water faster from one side to the other.
3. It is the end of year and if you can wait, you might find that newer tech and better pumps requiring bag upgrades may become avail or at a minimum a better price. I only have the proof from last winter, where there was a lot of innovation launched and I think there is a ton of room for improvement this year. Also, MC's new catalogue states 500% faster pumps... Not sure if that includes better sacs?
4. With the current bag tech, I'm considering buying a transfer pump to help with moving water around from bag to bag.
Old 12-01-2013, 11:49 AM
Boat: 2014 X30 GEN2
2. Consider that newer bags (Ronix 8.3) that may let you transfer water faster from one side to mthe other.
Thanks for the help, I think I will go for the 1100's as well, any suggestions on material to reinforce the plastic engine wall? Thinking of an aluminum angle iron so corrosion will not be an issue, or perhaps square tubing might look better. Also what other spots of reinforcement do u think it needs?
Old 12-01-2013, 01:34 PM
Stefan's Avatar
Stefan Stefan is offline
I did a welded diagonal aluminium cross of 20mmx30mm aluminum profiles that stretch all the way into the corners of the panel that splits the compartments, bolted onto the enginge side with a couple of screws. Not much more than that though, thought about a full length u-profile on the bottom at first but in the X-15 the panel sits fine behind the small panels in front and rear of it.
If You Find To Many Capitals You Can Keep Them...I'm German
Old 12-01-2013, 01:41 PM
jradasaurus's Avatar
jradasaurus jradasaurus is offline
Boat: 2009 Mastercraft X-Star
Could you take a few pictures of this or describe it more? I'm considering doing the same. How did you bolt it to the flooring? Are the two welded aluminum parts square? .. and are they interlocked at the center or just welded side by side?
Old 12-01-2013, 03:42 PM
Boat: 2012 X30, 6L
Here is another thread on it...
http://www.mastercraft.com/teamtalk/...ad.php?t=48062
I've ask my dealer and they mentioned that the 2014's have some improvements... I think that lengths of aluminium T or channel across the bottom and middle sections would help.
It's a next year project for me.
