  #191
Old 09-04-2013, 01:11 PM
SP Maristar's Avatar
Sorry i wasn't able to post my trans video quick enough. Let's just say that after watching your video and hearing my trans, i think pulling it is a good plan. You got a lot of work done in a short amount of time. Spring should be fun after some winter time trans refurb.
Old 12-10-2013, 09:25 PM
bluebicycle100 bluebicycle100 is offline
Boat: Mastercraft Maristar 200 VRS 1998 5.7 Indmar
Wow I just found this .. I purchased a 98 200VRS this last June and I am almost through with fixing up the mechanicals and repairing the hull. I have a suggestion for anyone on a shaft seal . OJ props makes a feat shaft seal water cooled...
Old 12-10-2013, 09:27 PM
Here is the link incase anyone needs it....http://www.ojprops.com/products
Old 05-18-2014, 08:34 AM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
Originally Posted by hig View Post
Oh yeah, nothing but progress from here on out!!!
Here a teaser of my side decals Mike made for me, they are replacing the Maristar on the sides.
I can't wait to get them and put them on.
Steve
Were you able to completely eliminate the shadow from the original MariStar decals? My boat had far less sun damage than yours but I was unable to completely eliminate it. I wet sanded extensively, then compounded and polished. It's still there if you look closely enough. I'd like to put similar MasterCraft decals over mine but I've thought it might make the old MariStar in the gel coat look more obvious. Did you ever put these decals on?
Old 05-18-2014, 06:12 PM
hig's Avatar
hig hig is offline
I was not able to completely remove the old outlines but I didn't really think it wouls show up much with the new decals.
I put all but the big MasterCraft on last summer. I will be getting the boat out of storage soon so hopefully I will get those on and take some pics.
Steve
My progress thread: 1998 Maristar 200 VRS
Old 05-18-2014, 06:21 PM
Boat: 2000 230 VRS
Who is Mike and how much did he charge for the decals?
Old 05-22-2014, 12:00 AM
jsturvey's Avatar
jsturvey jsturvey is offline
Boat: 1998 MariStar 225VRS
Steve
Good to see you again hig! Was wondering if you had finished your boat. Did you ever get the issue with your transmission sorted out?
Joe
1998 MariStar 225VRS, 350ci LT1
Authorized Dealer for
Old 06-11-2014, 12:01 PM
hig's Avatar
hig hig is offline
I just posted about my trans:
http://www.mastercraft.com/teamtalk/...ad.php?t=61488
I don't see anything wrong with it internally.
So far I've recieved one reply that it's normal for the trans.
Steve
Old 06-11-2014, 01:16 PM
Boat: 1998 Maristar 200VRS
I'd step in with some brilliant insight on your transmission problem, but I've got nothing for you.
My trans is silent in neutral and forward, and has a whine in reverse. Nothing that sounds like rocks at idle.
Old 07-06-2014, 09:17 PM
hig's Avatar
hig hig is offline
Update:
I finally put the trans back into the boat. I ordered new seals for the trans since I had it all apart and I was talking to Alan at http://www.simplicity-marine.com/ and I told him about my noise. He immediately told me it's my dampening plate, he said around 4-500 hours the old plates can start letting the vibration threw. He recommended a vulcanized 2 stage plate and he had a couple of take off's with low hours that he sold me reasonably.
It completely solved my "rock in the trans" when I placed it in gear!!!
I now need to go thru the driveshaft alignment process again and finish putting it back together.
I might actually get to use it this year!!
Steve
