  #111
Old 06-17-2013, 06:38 AM
hig's Avatar
hig hig is offline
Originally Posted by FrankSchwab View Post
I'm not sure I agree. I believe that's an electronic sender, and needs to have 12V fed into it to work right; then it simulates the appropriate resistance. I think I'd put it back in-circuit and measure the voltage across the sender as you raise and lower it in the tank - no change, new sender.
That's already a replacement, and not the one that came with the boat.
Would you be able to explain how to test it, either describe it in detail or attach a sketch? I would hate to change it if I didn't need to.
Would you know why in "mtajpa" thread:
http://mastercraft.com/teamtalk/showthread.php?t=48823
the old seader (like mine) does not measure correctly but the new one measures correctly, is it a different style, electronic compaired to mechanical slide?
Thanks, Steve
Old 06-17-2013, 06:46 AM
hig's Avatar
hig hig is offline
Originally Posted by barefoot View Post
Hig...Just started reading this, and to say the least, I'm impressed with what you've accomplished! It seems you know your way around cars/boats, which leaves me with one question: Why a Bayliner?
Your MC will be a world of difference from your old boat. My guess is you'll wonder why you didn't make the move years ago!
Thank you for the compliment!! I guess I didn't know better with the Bayliner. I got an awesome deal on it and it has been a good boat but the quality of the MC is so much better!!
BTW, here's another project I've been working on for over 3 years, a 1972 Camaro.
but for some reason I keep getting sidetracked with other projects.
Steve
Old 06-17-2013, 09:24 PM
hig's Avatar
hig hig is offline
I had a friend at work strip and powder coat the ski platform brackets for me, I gave him $25 to do it. I think they came out good.
From the factory what held the teak platform "L" bracket down in the bracket that bolts to the boat? When I bought the boat it just had a couple of steel cotter pins in the holes at the bottom of the brackets.
Steve
Old 06-17-2013, 09:27 PM
SP Maristar's Avatar
These guys hold the platform on!Name:  ImageUploadedByTapatalk1371518830.648549.jpg
Old 06-17-2013, 11:40 PM
Boat: 1998 Maristar 200VRS
Thanks, Steve
I will step out of this conversation now; his write-up is authoritative and excellent. Apparently that style is not electronic like I thought, and yours definitely looks like it needs replacement. BTW, I ended up with a replacement that looks exactly like the new one he got, from WEMA. I'm quite satisfied with it.
Old 06-18-2013, 06:50 AM
hig's Avatar
hig hig is offline
Last question (for now):
What is this? It was screwed under the dash and wired to the stereo power and runs all the way back to where the motor should be, I do not know where it was hooked. Is it a circuit breaker, all that's on it is 12 volt?
Thanks, Steve
Does anyone know what this is?
Thanks, Steve
Old 06-18-2013, 09:41 AM
Sorry Steve, it doesn't look familiar.
Old 06-18-2013, 10:27 AM
Dylan's Avatar
Dylan Dylan is offline
Boat: 15' VALCO
Looks like it might be a relay?
Old 06-18-2013, 05:52 PM
hig's Avatar
hig hig is offline
Should there be a 160 degree t-stat in here? When I pulled it apart there was nothing there?
I found the 140 degree one but not the 160. Is it missing or am I looking in the wrong spot?
Thanks, Steve
Old 06-19-2013, 01:35 AM
Normally with a relay, you'd need at least three connectors on the bottom - one for +12 to activate the relay (grounded through the case), and a guzinta and guzouta terminal. With only two terminals on this one, I'm at a loss - perhaps a circuit breaker (although it appears to be labeled with "12 v", not a current rating), perhaps something else. Really hard to tell.
/frank
