Old 05-16-2013, 07:02 PM
Bluccous's Avatar
Bluccous Bluccous is offline
Boat: 1985 stars and stripes
Carburetor question
I have a question about the secondary side of the carb. It is a standard marine Holley 600 with electric choke. The motor is running and idling good, but the back barrels don't seem to be opening up. I have taken the rpm's to 4000 on the trailer but still not opening. Not sure what is going on . Any help appreciated!!
Old 05-16-2013, 07:17 PM
They won't open up unless the engine is under load. You won't be able to get the vacuum low enough without doing some damage to your engine. If you are suspecting that they aren't opening, you will need to do an on the water test with the engine cover open or off to see.
Old 05-16-2013, 07:18 PM
If the secondary diaphragm is bad, it won't open at all.
Old 05-16-2013, 07:34 PM
Bluccous's Avatar
I was thinking that but wanted to ask for sure. Thanks!
Old 05-16-2013, 09:59 PM
No problem.......that's what this place is all about. Well, that and pictures.
Old 05-17-2013, 12:35 PM
markismm's Avatar
markismm markismm is offline
Boat: 1984 Stars and Stripes
You can make them open up manually through the use of compressed air. See this link which is helpful in diagnosing your problem in the driveway.
http://www.chevyhiperformance.com/te...ary_operation/
Old 05-23-2013, 10:40 PM
1988prostar190 1988prostar190 is offline
Boat: Mastercraft Prostar 190 Indmar 351 Ford Windsor
also if your piont distance is off the timing will be off which doesnt give the cycle enough vacume to open the rear barrels, this was just set up von my boat. Mine was a quick fix in the rotar cap
carburetor, holley
