Old 05-13-2013, 04:09 PM
Shawnymac11 Shawnymac11 is offline
Boat: 1992 Mastercraft Prostar 190
Stereo install from scratch
Trying to install a head unit in my 92 Prostar. There is NOT a stereo in it at all. Where would you suggest I tie in to get power?
Old 05-13-2013, 04:24 PM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Will you be running a single battery, or dual setup? If possible, just run it straight to the battery.
-Mike
Old 05-13-2013, 04:54 PM
Yea just using the battery already in the boat. Just run one long power cord from the head unit to the battery?
Old 05-13-2013, 04:59 PM
Datdude's Avatar
Datdude Datdude is offline
Boat: 2016 X10
I need to do a new install on a 2000 Sportstar too. It should be a fairly simple project (I hope)
Always Happy.......Never Satisfied
2016 X10
39 Mastercrafts and counting
Old 05-13-2013, 07:59 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
You could put a jumper on the purple wire from your ignition but most of our boats are old and there is a pretty big voltage drop. My radio will only go to about 75% before it kicks off from lack of power. If you run a new wire all the way back to the battery, you won't have to worry about old wire issues.
Old 05-15-2013, 03:17 PM
Wake_Winnipeg Wake_Winnipeg is offline
Boat: 92 Prostar 205
Check under the dash you might have accessory wiring sitting there that is pre-wired to the battery, also look near the back seat there are pre-cut speaker holes.
Old 05-16-2013, 11:55 AM
I have to ACC switches one is for the cigarette lighter under the speedo an I don't know about the other one. So hard to trace wires when there all in that plastic tubing bunching them together
Old 05-29-2013, 04:41 PM
willbarber1989 willbarber1989 is offline
Boat: 1991 Mastercraft Prostar 190
There is a ACC and Ground wire coming off the key side of the dash, I just tied my headunit into that just last night and it works great. Mine were pinned up underneath the dash and are labelled right on the wires as to what they are.
