Old 05-13-2013, 01:53 PM
dvsone79's Avatar
dvsone79 dvsone79 is online now
Boat: '99 205v
Trouble draining oil. '99 205v
I can't seem to get more than a slow, brief trickle from the oil drain hose on my boat. I warmed up the engine for about 10 minutes, then stuck the hose out the plug hole in the transom, unscrewed the cap, and a very slow trickle came out for about 10 seconds, then nothing. Checked for kinks in the hose, and opened up the oil cap, still nothing. Am I doing something wrong? I thought it would be a pretty straightforward process...
Old 05-13-2013, 02:04 PM
Jerseydave's Avatar
TT Hero
I drain mine this way, but I let it drain overnight because it does go slow.
Your other option is to buy a Mityvac evacuator and suck the oil out of the drain hose with it. (Everyone should own one of these anyway....very useful)
I was njskier on here.
Old 05-13-2013, 02:06 PM
zsqure's Avatar
zsqure zsqure is offline
Boat: MasterCraft X-14, '09 Blue
Expressed the same thing to my dealer and they told me they leave them drain overnight because it is so slow. No clue how long it takes to warm the oil up. Half tempted to change the oil at the load ramp when it is hot from a couple hours hard running.
Old 05-13-2013, 02:29 PM
carlsonwa's Avatar
carlsonwa carlsonwa is offline
Boat: 2006 Prostar 197 TT
That's not a bad idea, it will take a while idling for the oil to warm up. A good 20 mins is what I give it when warming it up in the driveway.
Old 05-13-2013, 02:36 PM
run the engine for 30 minutes, it will pour out fast
Old 05-13-2013, 02:46 PM
etduc's Avatar
etduc etduc is offline
Boat: Something else, DD 2004 red/white/black
Draining the oil, via drain hose, will never be as fast as removing the drain plug from say the engine in your car. The hose fitting, screws inside the oil pan fitting, therefore smaller inside diameter. In theory, older boats could have sludge buildup, reducing diameter more.
So, you can't increase the drain rate (much) by gravity/slope...just takes time.
Years ago, my dad's boat mechanic (i/o), would remove the drain plug... and let drain into the bilge and then out the boat drain! We had to soak the drain plug, in dish soap, so it would not pop-out of the hull!
Ayyyy!
2004 Red/White/Black something or other.
Formally, 1994 RED Mastercraft 205, Chevy 5.7 TBI.
Old 05-13-2013, 02:59 PM
chriscraftmatt1976
He's correct, always change the oil with the boat warm and it will pour right out. I do have one of those sucker pumps, too, and they are nice. with the combination of the pump and a warm boat, I can change my oil in 10 minutes.
Old 05-13-2013, 03:22 PM
what i do is go out and ski/boat... go back to stall and start drain... leave it draining. when i go back out, i swap oil filters, plug it up and fill with 5.5 to 6.
Old 05-13-2013, 03:32 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
It's a little different with a v-drive. Even when warm, the oil doesn't pour out.
The first time I changed mine, I let it drain for 6 hours or so. I use a mityvac now.
Old 05-13-2013, 04:24 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
Had this same issue- even after warmed up. Bought a 7$ harbor freight hand pump and had it emptied in 5mins.
