Rear LED Trailer Light
Hey guys, the rear brake/turn light on my 07 trailer isn't working properly. It lights up with the running lights and shows that it has power but does not indicate braking or turning. I'm guessing that its wiring or possibly a grounding issue but wanted to get your guys input. Thanks!
-Lenny 2007 MasterCraft X-1, RTP-1, Ballast, MC Cruise, swivel board racks, Glacier White and Midnight Black |
Have you. Checked braking and turning at the source? I had same issue and it turned out the problem was at the truck.
I'm having the same issue with my 07 trailer
Make sure your vehicle is putting 12v on the correct pin at the trailer/vehicle connection.
'96 ProStar 205 SD LT-1 |
Is it possible that it could be the truck even if the drivers side of the trailer lights are working as normal? It's just the brake/turn signal on the passengers side of the trailer that isn't working. When I turn the headlights of the truck on, the running lights for the trailer all work, even on the side where the brake/ turn signal does not.
You basically have four wires coming from the truck (plus a possible fifth for the reverse solenoid).
Listed in no particular order 1) Common ground 2) Running lights, side markers, etc. all on one wire 3) Left side high intensity only (brake & turn) 4) Right side high intensity only (brake & turn) If your truck lead for the passenger's side high isn't good, your trailer will have everything but the right side brake and right turn. It would be good to make sure the truck wire was good before you started in on the trailer. It might save some head scratching. Turn your right turn indicator on and use a test light to see if you can find a blinking hot wire at the plug. If you don't have a multimeter, you can use a tester like this: http://www.harborfreight.com/extra-l...ter-43700.html You could also pick up one of these easy truck testers: http://www.harborfreight.com/four-wa...ter-66526.htmlhttp://www.harborfreight.com/four-wa...ter-66526.html Some adapters have lights as well: https://www.easternmarine.com/index....FcIv4AodlnsAmA
The first thing to do is check the fuses. I don't know if that vehicle has a fuse for each wire or not, but check. I think those fuses are in the box under the hood on the drivers side.
I just checked an online manual and it looks like you have a "Left" and a "Right" trailer brake/turn fuse.
'96 ProStar 205 SD LT-1 Last edited by Table Rocker; 05-12-2013 at 08:55 PM. |
You might check the connections for the trailer harness. It will be across the back and I think it will have a plug on each end and the trailer wiring in the middle. I would unplug all the plugs and plug them back in. See if you can find any problems. Make sure the vehicle's turn signal is working on that side.
It would have been easier to find the problem if it was the trailer wiring. That's the bad news.
Regardless, I will check the fuses tomorrow. It's possible that one of them could be bad. Although it might be worse that the problem is the truck and not just the light, at least I have a concrete place to start my investigation. I know I've knocked the light receptacle off on some snow banks so I may have damaged one of the wires.
Thread Tools | |
Display Modes | |
