Old 05-12-2013, 09:40 AM
djkslc djkslc is offline
Boat: 2008 X-2 MCX
Disappointed in towing
I traded in my wife's 08 Tahoe 5.3 motor with 100k miles for a 12 gmc Yukon 5.3 l with 15k miles. I towed my 02 xstar yesterday for the first time yesterday. The tow includes a large climb over parleys summit. This gmc would not down shift the way my 08 Tahoe did. I was in tow/haul mode and had the gas pedal down all the way and the down shift took forever. I could do 65 or so up and over the summit in my 08 and I was struggling to be at 50 in the gmc due to the fact it didn't down shift to keep the speed consistent. What am I missing
Old 05-12-2013, 10:07 AM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Different rear end. When they went to the 6 speed they also put substantially higher gears in the rear ends for the sake of economy.
Old 05-12-2013, 10:28 AM
1redTA's Avatar
1redTA 1redTA is offline
Yep the solution is too find a 3.73 to go with the 6 speed like what was probably in your 08 with a 4 speed. I think the 6 speed uses a 3.08 or 3.23. Also, you can tow in 5th gear to help
1981 MasterCraft
19' Skier 351W PowerSlot
Old 05-12-2013, 10:47 AM
mustangtexas's Avatar
mustangtexas mustangtexas is offline
Boat: 2005 MasterCraft Prostar 197 & 1989 190
Your GMC is under warranty. Take it in and have it checked out. Even with a higher rear differential ratio the lower ratios of the first 4 sets of the 6 speed auto give you a better low end final drive ratio for towing. The sixth gear set is to give the extra miles per gallon rating on highway and all six allows for additional city MPG as under normal driving shifts come quicker reducing rpm. Results help raise the all important CAFE rating. At first glance your issue sounds like a programming issue or a speed sensor.
Old 05-12-2013, 11:47 AM
nickespi's Avatar
nickespi nickespi is offline
Boat: 2002 MasterCraft X-30
Something is going on. The 4 speed and 6 speed have similar ratios in the 3/4/5 gear range. Definitely have it looked at.
Old 05-12-2013, 12:03 PM
Is there an OD button and was it turned off?
Old 05-12-2013, 12:07 PM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
Some times you can look into a .. Super chips, or bully dog system.. to reprogram your truck and in tow modes change shift points
Old 05-12-2013, 05:51 PM
Indyxc Indyxc is offline
Boat: 2006 Mastercraft X2
Something is wrong...
I towed my last boat from Florida to Michigan with a 5.3 Tahoe with a 6 spd, and through the mountain of Kentucky/Tennessee the trans was shifting into 4th to maintain 75 mph.
Old 05-12-2013, 07:11 PM
pap pap is offline
tow/haul generally limits shifting, but that sounds extreme. The different rear end would explain more frequent downshifts, not what he describes.
Either your tranny is not programmed correctly, or perhaps that particular model has a real slow downshift mode in tow/haul.
You can always manually drop it down, yes?
Old 05-12-2013, 10:23 PM
Miss Rita's Avatar
Why would you stress your Tahoe to maintain 75 mph uphill? You must have had it floored; seems like you're flogging it a little. Not to mention that ST tires are rated to 65 mph.
