Old 06-14-2012, 07:38 AM
Tomi Tomi is offline
Boat: MasterCraft Prostar 190, 2003
Packing related questions
2003 Prostar 190... 1:1 transmission and 5,7 RTP-1, it has 1 1/8" shaft and packing was leaking. So I took the usual route and ordered 3/16" graphite seal from Skidim. Started to replace when I realized that old rope seemed clearly larger than the new 3/16". Installed it anyway... fitted 4 rings without any trouble. The rings seemed definitely spacious if not even loose inside the nut.
Tightened the package and went for a test drive. No leaks. It seemed to work ok. Some really minor drips when running, even loosened the nut a little. Gets warm but not really hot.
So my question is: How tight should the rope be when fitted to the nut, should I order 1/4" packing seal instead... can I really have 1 1/8" shaft that would take 1/4" seal?
-Tomi
Old 06-14-2012, 03:35 PM
1redTA's Avatar
1redTA 1redTA is offline
on my 81 powerslot the prop shaft is 1 1/8th" and uses a 3/16" packing. your 1:1 should be 1" and use a 1/4" packing. I'd measure again??
1981 MasterCraft
19' Skier 351W PowerSlot
Old 06-14-2012, 04:35 PM
Boat: 1998 Maristar 200VRS
I think 1redTA has it nailed - I believe the 1:1 boats all used a 1" shaft, and need 1/4" packing.
But, if it's buttoned up and not leaking, I'd probably let it go.
/frank
Old 06-14-2012, 04:38 PM
Per OJ in some other thread, since 2003 all have 1 1/8" shafts, also 1:1. I also measured it a few times, so shaft is surely 1 1/8".
Old 06-14-2012, 07:44 PM
John 3:16-18
Old 06-14-2012, 09:11 PM
I learn something new every day.
Time to go skiing.
/frank
Old 05-28-2013, 04:10 PM
brad's Avatar
brad brad is offline
Boat: 04' prostar 197 TT
Size of prop shaft packing replacement on 04 PS197 TT. Does anyone know? Tired of waiting to here back from dealer for info and where to find if dealer does not have in stock.
