Old 05-10-2013, 11:44 AM
chriscraftmatt1976
Originally Posted by jdl xstar View Post
Correction... 6 weeks. Dropped it off on March 29.
wow... that's a long time to be working on a boat... a really long time. Have they localized where the noise is coming from? they should have a stethascope style thing that they can listen to the engine with and at least tell where it's coming from...
Old 05-10-2013, 11:50 AM
jdl xstar's Avatar
jdl xstar jdl xstar is offline
Boat: none at moment
Good question. My hunch is that they don't because he has just been telling me how hard it s been to locate the problem which is why they've had to take it apart. He said if they can't find the problem after taking engine out, he said they'd send the engine to another mechanic shop.
He said that they are equiped to handle most engine issues, major surgery isn't necessarily what they do so they would have to outsource that. To me, all I'm hearing is money flying out the door.
Previous - 2007 X-Star w/ 8.1l
Previous - 2007 X2 w/ MCX
Old 05-10-2013, 01:04 PM
chunter's Avatar
chunter chunter is offline
Boat: 1999 Prostar 205
are you sure that the spark pluge that they put in are not to long and were not hitting the pistons.
Old 05-10-2013, 02:15 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
He said they pulled the heads already. So eliminates spark plug interference.
IF they actually removed the heads??
IMO top end and injectors "click". Nothing in the bottom end clicks if its effed up. It knocks or clunks!
If they got you for 15+ hrs already and haven't used a simple stethoscope they are idiots. End of story.
Hope this turns out well but sounds like you're being taken for a ride.
So what's the noise sound like? You hear it run yet?
'06 X2 MCX
Old 05-10-2013, 02:19 PM
Thrall's Avatar
Boat: '06 X2 MCX
To add to my last comment. They are giving you the runaround. Can't see anything by just pulling the engine unless you remove the oil pan but they're gonna outsource that ?
You can look into the cylinders with a bore scope. That and a comp ck will tell a lot. No need to even pull the heads.
Can someone help this guy out?
Pulling the engine is the dumbest thing one coould do before isolating the noise. Then it can't be run.
'06 X2 MCX
Old 05-10-2013, 02:34 PM
bjames's Avatar
bjames bjames is offline
Boat: 2009 X-Star LY6
My truck had a clicking (more noticeable on idle). The clicking was more apparent when engine was cold. It turned out they replaced the manifold - clicking gone. Not sure if this helps, but just another idea.
I agree... If the problem gets worse while the dealer has possession, then they need to address it and not nickle and dime you to death.
Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower. c/w 1/9 scale R/C PWT X-Star
Owned:
2012 X25
2011 X25
2009 Moomba LSV
2009 Moomba Outback V
2008 Monterey FS180
Pelican 4 set paddle boat
plastic tug boat when I was 4
Old 05-10-2013, 02:41 PM
bzettler83 bzettler83 is offline
Boat: 2003 x30
You have to wonder if they ran the engine with no oil by mistake, and only realized it after it was too late.
I worked at a shop for a while and had a guy run an engine to bring it to temp and check the level, it took about 5 minutes to realize there was a problem.
Old 05-10-2013, 03:05 PM
jdl xstar's Avatar
They do plan to remove the oil pan in their own shop but if no problem is found at that point, they will send to a different mechanic. Regardign gettign the run around, I've had this dealership do other minor work and they have always been straight with me. I can sense the frustration on his part of not beign able to find and fix the issue since it looks bad on his part and he knows his rep is on the line. So I do believe they are just getting stumped. The whole deal stinks though
I believe they removed manifolds and they looked good.
This would be worrisome if this occured here but I'll toss it out to him and see how he reacts.
Old 05-10-2013, 05:18 PM
chunter's Avatar
here is another idea that i havent seen yet. does the engine have hydraulic lifters? they tick when one has collapsed.
Old 05-10-2013, 07:32 PM
petermegan's Avatar
Agree with the earlier comments about bottom ends are clunks and knocks, top end produces lighter noises in the valvetrain. Only small possibility is a flexplate cracked maybe, otherwise lifters? Clutching at straws but geez low hours for any problem. Have fun
