Old 03-02-2014, 01:07 AM
JustinE JustinE is offline
Boat: 1996 mastercraft prostar 205 , LT1
Interior panels
How do I get the interior panels off both the drivers side and port side of the walk way to the front bow on my 96 ProStar 205 ? Are they pressed in with plastic clips or bolted ?
Thanks for any help
Old 03-02-2014, 01:53 AM
Here are some pics...
http://www.mastercraft.com/teamtalk/...t=56789&page=2
my 1995 has christmas tree pins for the walk thru when checked last..
Old 03-02-2014, 09:09 AM
RoboF16 RoboF16 is offline
Boat: 2000 Mastercraft ProStar 205
First, remove the center section up front – should be held in by five press-in plastic retainers (Christmas tree style). Start with the bottom left and right corners first. I found it helped to have one of those automotive door panel fastener removal tools. Protect the fiberglass with a cloth.
Then, remove speakers so you can start to remove the 7/16 nuts/bolts that hold the side panels on. A ratchet wrench is VERY helpful and if your arms are not too big/long it is manageable. Each side will have one bolt at the very front of the side panel that you access through the hole uncovered by the center seat back. Then start to locate the others you access through the speaker holes. Last, you’ll need to remove the panel in front of the driver’s feet to get to the bolts near the driver and observer. Finally you’ll lift the side panels up, and off of the aluminum brackets attached to the fiberglass. Hope this helps.
Old 03-02-2014, 09:12 AM
About getting your arms through the speaker holes, etc…
The key is to get your elbow in there, so run your hand through whatever direction that provides the most distance/room to get the elbow through THEN you can go side-to-side searching for the 7/16 nuts.
Old 03-19-2014, 07:07 PM
waterlogged882 waterlogged882 is online now
John 3:16-18
interior panels prostar
