Old 05-18-2013, 08:05 PM
uplander uplander is offline
Boat: MC 2002 X30
Oil Bath Bearings question
My trailer has the oil bath bearings system, I have nerver had this system. One of them is low on the visual indicator. It looks like you take the tire off pull out the plug and drain the system and re-fill with 50W oil. put plug back in.
If I am missing something please reply, I am thinking about doing this tomororw as we have storms coming our way.
thanks for any input.
Old 05-18-2013, 09:08 PM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
What brand do you have???
I have Reliable and they recommend 50 wt half to three quarters up. I believe UFP says to fill them almost full
Old 05-18-2013, 10:15 PM
LittleFuss LittleFuss is offline
Boat: 2013 X14v
I have the Reliable brand on a 2004 model trailer. Owner's manual says 80-90st gear oil.
To answer the original question. Yes, you will have to pull the wheel to get the oil in. If you have the aluminum caps then there are definately seperate set screw plugs on the hub and the cap. reremoving just one of them allows you to put oil into the hub.
2004 MariStar 230 VRS with X Package
Come find us on 'da Bayou
Old 05-19-2013, 09:39 AM
Boat: MC 2002 X30
thanks I have the Gold Hubs
Old 05-19-2013, 06:38 PM
Boat: MC 2002 X30
I finished the project today, one tip I found was use a oil can to fill then instead of funnel. That made it much easier. Next time I am taking trailer off boat and rent a slip for the day and do work on trailer and return for boat.
Old 05-19-2013, 07:06 PM
I found a ketchup/mustard dispenser bottle like at Walmart with the thin pointy cap works well also.
