Old 05-05-2013, 07:28 PM
Lars's Avatar
Lars Lars is offline
Boat: PS197
leveling compound on cracked garage floor?
Bought my house about a year ago and the condition of the garage floor is driving me NUTS! I'd love to put down an epoxy over it, but it is very pitted and spalled. None of the cracks look structural, I think it's just 60 years of water freezing and thawing on top.
See pictures below.
Can I just clean it and put some leveling compound on this front half and then epoxy it? Back half was added much later btw.
Old 05-05-2013, 07:35 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
Wish I could help. You need someone who really knows about this. I'm thinking jack hammer it all up and start over including a little digout of the soil below and filling with good gravel and compacting properly.
Old 05-05-2013, 07:46 PM
John 3:16-18
Old 05-05-2013, 08:43 PM
JohnE's Avatar
Boat: XT22
A small project like that is really not difficult as a DIY if you plan properly. The key to any and all concrete placement is reinforcement and control joints.
If concrete moves (and it almost always will) it will crack. My understanding is that you either need to keep it from moving or control where it cracks. The first part is almost impossible, so control and expansion joints need to be installed. On the floors I just poured, the installer placed 1/2" foam around the perimeter for expansion and cut control joints in with a diamond blade saw. My last house was done the same way, and it's amazing that the floor cracked within almost every saw cut. You could see it if you looked into the saw cut. (I never did get around to filling the saw cuts with silicone - hopefully I do on this one.)
Old 05-05-2013, 08:52 PM
John 3:16-18
Old 05-05-2013, 09:11 PM
JohnE's Avatar
Boat: XT22
I do realize you have much more experience than I do in this. I was just trying to clear things up for OP. Expansion joints as name indicates allows for the entire floor to expand by creating a space for it to do so. Foam or some medium is placed around the perimeter where the floor abuts the walls. Otherwise it will crack upon expansion. Control joints (in the middle of the floor) create a weak spot such that when the floor does crack it does so in the controlled location.
Old 05-05-2013, 09:38 PM
John 3:16-18
Old 05-05-2013, 10:38 PM
BrooksfamX2's Avatar
Boat: 2007 X2
cover it with some garage matting or outdoor carpet?
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
Old 05-06-2013, 03:09 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Yeah drop in some of those rubber garage tiles.
Or pull it out and re pour.
'06 X2 MCX
Old 05-06-2013, 06:48 AM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Break it with a sledge. Put in new wire mesh, rebuild up the settled stone, compact it. Run expansion joint around perimeter only. Fill it up with Crete. Joint the floor into 4 pieces. California finish it so it looks pretty. That is all you can do to that floor. Any bandaids will not solve this issue. Good luck
Sent from my HTC VLE_U using Tapatalk 2
1 Corinthians Chapter 13 - 11
